cant bunout wtf
Old Oct 16, 2010 | 05:31 AM
most-hated's Avatar
most-hated
Originally Posted by Russ K
Have your tuner email your tune if he is using Hp Tuners, and I'll check it out for you.
Russ Kemp
ill try n do that
Originally Posted by 0331MARINE
Thats not good.....
why
Old Oct 16, 2010 | 07:31 PM
ZZ06's Avatar
ZZ06
Originally Posted by most-hated
ill try n do that
why
well hes saying that bc if your pressing the button and TC isnt disabling itself, there is a problem.
Old Oct 16, 2010 | 07:42 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Are there any codes in the DIC? If so post them up. When you press the TC/AH the light should come on and the DIC should say TC/AC off. If the light is staying on all the time and the button does nothing it means something is wrong.
Old Oct 16, 2010 | 10:43 PM
dankhts's Avatar
dankhts
Originally Posted by Bluefire
Have you checked for codes?
FYI Russ K can fix it!
He knows his stuff! Good 'ol Saskabushh boy! Lot's of good tuners have learned a lot by following his posts!
Old Dec 1, 2010 | 03:56 AM
most-hated's Avatar
most-hated
tried what russ told me to do and nothing still wont burn out the car seems to limit its power u can hear it in the motor, but if i just floor it it will peel out but if i apply the brakes for a burn out it wont
Old Dec 1, 2010 | 01:15 PM
TK6's Avatar
TK6
Maybe look at this thread? Seems like it could be what you are talking about. http://forums.corvetteforum.com/c5-t...nch-issue.html
Old Dec 1, 2010 | 02:01 PM
C5XTASY's Avatar
C5XTASY
Do you have a late 1998 with Active Handling? Mine did the same exact thing when torque braking. At 1200 rpms, the motor would begin downpowering. The more I pressed the throttle the more it would downpower. My understanding is that 2001+ C5s do not have this issue. Not sure if the issue is related to Generation 1 and 2 Active Handling, or if Traction Control was also modified in 2001.
Ed
Old Dec 1, 2010 | 08:28 PM
SueTaing's Avatar
SueTaing
do you have round tires installed? Square or Triangle tires are pretty hard to burn out :X
