Rear differential lubericant
Old Oct 13, 2010 | 08:36 PM
zribkl69's Avatar
zribkl69
Default Rear differential lubericant
What does GM use at the factory and what is everyone else using ?
Time to fix leaky butt syndrome.
Old Oct 13, 2010 | 08:37 PM
crainholio's Avatar
crainholio
Not sure what GM uses, but I've had great results with Redline and a tube of GM friction modifier additive.
Old Oct 13, 2010 | 09:30 PM
bumble-z's Avatar
bumble-z
GM uses their own lubricant ( 2 full 23 oz bottles & part of a third bottle), along with a 4 oz bottle of additive.
You drain the rear diff.
Then you add the 4 oz bottle of limited slip lube additive. #1052358
Then you add the axle lube to where it meets the bottom of the fill hole.
GM now has the limited slip lube additive allready mixed in their axle lube, but some service centers don't have it in their supply as yet.
When I switched my tranny & diff fluid out, I used Red line products. Good luck.
Old Oct 13, 2010 | 09:41 PM
ericdwong's Avatar
ericdwong
I use Amsoil Extreme duty 75W90. Think I tried Royal Purple a while ago too...
Old Oct 13, 2010 | 09:48 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
GM now recommends the 75W90 LS Synthetic gear lube with the friction modifier included already. I sell it if anyone is looking for some.
To Rear differential lubericant
