ngk........?
Old Oct 14, 2010 | 02:01 PM
vette29209's Avatar
vette29209
Default ngk........?
hello..!
just wondering should I run ngk spark plus in my 1998 vette ..? what do you think..?
Old Oct 14, 2010 | 02:02 PM
memphis_vette's Avatar
memphis_vette
i have heard NGK TR55 are nice and they are cheap but i had a bad experience with them...do it the right way and put AC Delco iridiums in.
Old Oct 14, 2010 | 02:08 PM
dougbfresh's Avatar
dougbfresh
Old Oct 14, 2010 | 02:10 PM
craig04c5's Avatar
craig04c5
Depends. What do you want? TR55's last about 30K miles. Irradium's last at least 60K. I went with the TR55's because I don't mind changing them and they were a lot less expensive.
Old Oct 14, 2010 | 02:26 PM
98vettedave's Avatar
98vettedave
Originally Posted by vette29209
hello..!
The NGK's will work just fine,but some of the other manufactures products will provide a longer plug life. However,if you ever go boosted or nitrous then NGK's are a must. They provide an additional safety margin when things go south...better a melted strap than a blown piston.
Old Oct 14, 2010 | 02:34 PM
MawneeC5's Avatar
MawneeC5
Ngk ftw!
:d
Old Oct 14, 2010 | 02:57 PM
dougbfresh's Avatar
dougbfresh
Are they less than 1/2 the price?
Old Oct 14, 2010 | 03:02 PM
memphis_vette
yes they are less than half the price but i have heard that the iridiums last up to 100k miles...also said guaranteed for 100k miles on my box of iridiums
Old Oct 14, 2010 | 03:12 PM
ZZ06's Avatar
ZZ06
....put a set in when i had my headers installed
Old Oct 14, 2010 | 03:40 PM
MawneeC5's Avatar
MawneeC5
My thing is, even though the iridiums can go 100k, I cant ever see myself going 25k without pulling them to check anyway. So I might as well throw in a fresh set while I'm in there. If you have any engine mods done they may NEED replaced more often due to rich/lean spots in your tune. In that case putting the more expensive plugs in would be even less viable.
Old Oct 14, 2010 | 04:56 PM
ZZ06's Avatar
ZZ06
i know but one can have the security mindset (i do atleast) knowing that the iridiums can go the distance where as the NGK's is a MUST change. And like you said, with mods, youd be changing even SOONER with the NGK's....just going off what you said.
To ngk........?
