New Engine Problems, possible blown...
Old Oct 17, 2010 | 06:10 PM
Roger Z06's Avatar
Roger Z06
Originally Posted by BHRZ06
Is it bleeding air down fast on all the cylinders or just a few? Might want to consider pulling the heads first as its possible the valves may have floated and kissed the pistons.
Okay, I def will Only problem is it would be running bad/idling rough if the valve was bent.
Old Oct 17, 2010 | 07:38 PM
BHRZ06's Avatar
BHRZ06
Not really i had 2 bent ex valves and still dynoed at 420 rwhp and the car idled smoothly. Probably a slight bend like what i had Not a huge bend just enough to let out pressure. its a possibility right and easier than checking the rings. When you hook up the compression tester wheres the air going the crank case? or out the intake or the ex?
Old Oct 17, 2010 | 08:59 PM
Roger Z06's Avatar
Roger Z06
Pretty sure crankcase man, I think I can hear it in the dipstick tube and on the other side of the engine coming out of the push rods.
Old Oct 17, 2010 | 09:02 PM
lucky131969's Avatar
lucky131969
What is the result of the compression test?
Old Oct 17, 2010 | 10:55 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
To leak air out as fast it's going in, you got something other than ring problems.
I would think that you would be getting P0300 mis-fire codes.
Old Oct 17, 2010 | 11:03 PM
lionelhutz's Avatar
lionelhutz
The rings should have been seated by 500 miles.
It doesn't seem to me than an over rev would cause multiple cylinders to suffer ring failures without anything else happening. Usually you get away with it or you damage other parts like a piston, a rod or valvetrain parts.
That was my thought too.
Peter
