Drag race an automatic
Old Oct 15, 2010 | 06:58 PM
alankb's Avatar
alankb
Default Drag race an automatic
What would be the preferred launch method with an auto trans? Rev engine with brake on?
Old Oct 16, 2010 | 12:41 PM
rebelheart's Avatar
rebelheart
As I understand if your computer sees over 1200 rpm and no mph it will begin to take out timing.After many passes I have run my best times launching at a slight increse in rpm (1000) and letting the trans shift itself.Running 12.82 with a stock car with only a Vararam and Corsa catback with a predator tune.(3.15 gears)
Old Oct 16, 2010 | 02:01 PM
dankhts's Avatar
dankhts
I do my burnouts in 1st gear,shifting into 2nd, leave the line at 1500 rpm with the gearshift in 3rd and let it shift itself, my trans tune is 1st to 2nd @ 6300 rpm, then 2nd to 3rd @ 6400 rpm, running 11.42 with 3.42, 2800 Vig, and a few other mods...
Old Oct 16, 2010 | 04:16 PM
alankb's Avatar
alankb
Default thanks
I assume you have traction control in the competitive driving mode, right?
Old Oct 16, 2010 | 07:18 PM
C5XTASY's Avatar
C5XTASY
What are your mods, what kind of tires are you running and what kind of rwhp and torque are you putting down? Reason I ask is I'm having some real traction problems and am changing out my 3.73 gears to 3.42s. Kind of curious what to expect. Thanks for any info.
Ed
Old Oct 16, 2010 | 09:36 PM
Mark-44's Avatar
Mark-44
Default Launch = off at idle...
My stock long block LS1 does good from idle; lately have been launching from 1200 RPM. Best time is 11.75 @ 116 MPH with the original 2.73 differential. Basic modificataions are Vig 2800 SC and LS6 intake with Callaway Honker and longtube headers. Good luck.
Old Oct 16, 2010 | 10:37 PM
dankhts's Avatar
dankhts
Ed
baby cam 220/220/581/581/114 LSA, (Vengence racing) fingersmelter (Lingenfelter) ported 243's, yella Terra, 25%$ UD, LG long tube pros, stock injectors, dyno only 410hp/405tp, good tuner though, Nitto drag radials 275/40/17, Vig 2800 (hits at about 3000) 3.42 3-rib with clutches and up graded shafts, run pretty steady 11.42 - 11.50 up here (humid) @ 121 mph...I could probably go with a bit more cam as my heads flow a little over 300 CFM @ 600 lift...but the car runs like stock, gets good MPG on the highway (28-30) and my wifey drives it pretty much every day.way more than I do...
Old Oct 16, 2010 | 11:43 PM
motogib1's Avatar
motogib1
I also rev up to at least 1200 rpm and mash the pedal at the light. Running 11.63 at 118. Best 60' 1.719 with Vig 2800 and 3.42 gears.
Old Oct 18, 2010 | 04:55 PM
paint it black vette's Avatar
launching 2000,2100 3600stall 3.73 gears 1.4 sixties
Old Oct 18, 2010 | 04:56 PM
Ed
what stall, tires,and air pressure
Old Oct 18, 2010 | 08:50 PM
motogib1's Avatar
motogib1
I've never tried running in third gear. Is it quicker than in drive? Hard on the tranny?
Old Oct 18, 2010 | 09:09 PM
done both doesnt matter. when running in 3rd when you cross line the gear will help you slow down faster as compared to the limp shift into overdrive and a lower gear ratio. hard on tranny dont know.
Old Oct 18, 2010 | 09:10 PM
t/c off for me
Old Oct 19, 2010 | 04:15 AM
David426's Avatar
David426
Ed
Way Too many variables left unanswered by the original poster for an accurate answer from anyone... Track prep and Density altitude also play a factor.. Here in Texas at The Motorplex (Ennis Texas) on a cool dry day at 435 feet elevation my old 99 a4 3.15 geared C5 would do its best if I just floored it. Thats with stock Goodyear Runcraps ,no other mods,bone stock... As I modded the car and changed tires my launch Technique changed. Drag Radials will change the way you launch your car too... In all honesty to Alankb.. you will have to get out to the track yourself and make 4-5 runs down the track(maybe more or maybe less) until you get the perfect launch down.. As you can see you will get a dozen different answers based on a dozen totally different variables/circumstances
Old Oct 19, 2010 | 10:17 AM
alankb's Avatar
alankb
Default all good
I agree, many variables. Thanks for all the good info!
AL
Old Oct 19, 2010 | 01:52 PM
98tadriver's Avatar
98tadriver
niceee! I have a vararam and 273 gears but i ordered a circle d converter (3200-3400rpm) no headers yet. what are your 60' times? this gives me something to look forward to after headers and converter
i torque my stocker to maybe 1000rpm just to preload the suspension a lil and then floor it. seems to yield my best times
Old Oct 20, 2010 | 02:20 PM
Mark-44's Avatar
Mark-44
The 2:73's are okay off the line with either MT or Hoosier DR's. Usually the 60-foot times are 1.73 to 1.75. Track prep was better on my last two runs and a 1.691 60' got the Arctic White down the track in 11.781@ 115.67 mph. The last pass was the best ever with a 1.683 60' 11.752@ 116.04. Good track prep plus good air equals better times.
To Drag race an automatic
Old Oct 20, 2010 | 03:39 PM
chaase's Avatar
chaase
St. Jude Donor '12
I use the same basic technique. I load the drive train but that is about it and have gotten down to 1.667. I run both TC and AH off and I do the burn out and run in 3rd gear.
Old Oct 20, 2010 | 07:55 PM
David426's Avatar
David426
Just curious.. Why would you turn off Active Handling?
Old Oct 21, 2010 | 01:01 AM
98tadriver's Avatar
98tadriver
sweet. thats a pretty darn good 60' for having 273 gears! cant wait til my circle d 3200-3400 gets here
