Help, Broken Rocker Panel !
Old Apr 2, 2002 | 02:22 PM
Ray'98's Avatar
Ray'98
Default Help, Broken Rocker Panel !
Yup, someone finally broke the rocker panel where it bolts to the bottom of the fender. Has anyone made this repair? I see Ecklers has a kit, a piece of plastic to replace broken one ($40 for a bit of plastic). Will I need to remove the fender? Any hints or suggestions will be welcome. TIA
Old Apr 2, 2002 | 02:29 PM
zoomie's Avatar
zoomie
Default Re: Help, Broken Rocker Panel ! (Ray'98)
I had this problem, too. Nothing worse than a floppy fender. I'm ashamed to say how I fixed this, but it involved the use of some epoxy glue and duct tape to hold the parts together while the glue set up. Not elegant, but it stayed together for nearly a year and only I knew about it. :bb
