Oil Change
Old Oct 18, 2010 | 12:17 PM
dbfrdan's Avatar
dbfrdan
Default Oil Change
Did my own oil change and put in 6 quarts of synthetic oil. My gauges show 30% oil life and reads low oil level. How do I reset?
Old Oct 18, 2010 | 12:26 PM
rboineau's Avatar
rboineau
Been a while since I did mine, but I believe you have to have the ignition "on" but the engine off. Then bring up your oil life on the screen, press and hold "reset". Oil life should then show 100%.
Also, check your oil level when the car has sat for a while. May need a tad more than 6 quarts to show full on the stick.
Old Oct 18, 2010 | 12:58 PM
dbfrdan's Avatar
dbfrdan
Old Oct 18, 2010 | 01:24 PM
Oldvetter's Avatar
Oldvetter
Yep, you need to put in 6.5 quarts of oil.
Your low oil warning comes on at 1/2 quart low, I tested it when filling up oil.
Old Oct 20, 2010 | 01:43 PM
Vettmann17's Avatar
Vettmann17
I believe the HUD displays only the oil pressure, same as the analog on the dash, not the actual oil level.
Old Oct 20, 2010 | 02:34 PM
Joe C's Avatar
Joe C
Originally Posted by dbfrdan
How do I reset?
you read the owners manual - .
To Oil Change
