RR speed sensor variation
Old Oct 19, 2010 | 01:36 AM
vetteracerx's Avatar
vetteracerx
Default RR speed sensor variation
My friend has a 2001 ZO6 that I compleatly rebuilt. 170K. Problem is the RR speed sensor keeps throwing a code. It will show excessive variation or the shorted or open circut codes. The tech 2 snap shot will sometimes show speed signal spikes. I have replaced the speed sensor and the EBTCM. I used a breakout box at the EBTCM. It also showd variation in the speed sensor signal. It will spike high or low. My question is will resistance in the signal wire cause a false high speed AC signal?
Old Oct 19, 2010 | 07:15 PM
vetteracerx
Ideas anyone?
Old Oct 19, 2010 | 07:31 PM
lucky131969's Avatar
lucky131969
What else is left? You replaced the WSS and the EBTCM.....that leaves wiring. I think you have answered your own question.
Old Oct 19, 2010 | 07:44 PM
vetteracerx
My question is can a bad wire cause a higher speed false? The WSS generates an AC voltage signal. Can resistance in a wire cause the signal to spike high? I graph three WSS w/tech 2. The RR will spike high or low. Thanks
Old Oct 19, 2010 | 07:52 PM
lucky131969
Yes.
Old Oct 19, 2010 | 09:43 PM
vetteracerx
thank you
To RR speed sensor variation
