Whining noise at startup
Old Apr 2, 2002 | 05:16 PM
NewfieC5's Avatar
NewfieC5
Default Whining noise at startup
After startup there is a high pitch whining noise in the area of the driver's side front corner which lasts for about 2 min. Sounds like a servo or electric pump.
Is this normal? What is it?
Glenn
:cheers:
Old Apr 2, 2002 | 05:54 PM
racetchr's Avatar
racetchr
Default Re: Whining noise at startup (NewfieC5)
The '98 I had with A4 did this on startup, think it is the electric air pump. On my '00, don't have that noise anymore. Don't know whats up with that. After a time I kinda liked the sound. Wouldn't worry about it.
Old Apr 2, 2002 | 05:59 PM
Jochen's Avatar
Jochen
Are you shure this noise is comming from the front ? If it is comming from the back i would say it is the fuel pump noise. There is a TSB out on that, and later Models should not have this prob anymore.
Jochen
Old Apr 2, 2002 | 07:12 PM
B. Stewart's Avatar
B. Stewart
Default Re: Whining noise at startup (Jochen)
Jochen
I agree. It's probably coming from the fuel pump, right behind the drivers left ear!
Old Apr 2, 2002 | 07:18 PM
Face's Avatar
Face
Default Re: Whining noise at startup (racetchr)
The '98 I had with A4 did this on startup, think it is the electric air pump.<SNIP> Wouldn't worry about it.
:yesnod: :yesnod: :yesnod:
Old Apr 3, 2002 | 12:10 AM
NewfieC5's Avatar
NewfieC5
Jochen
No it is definitely coming from area around the drivers side headlight. Can only hear it from outside the car.
Now to display my stupidity - what's an airpump and why does it only run for 2 minutes? :confused:
Old Apr 3, 2002 | 12:39 AM
Vette XP's Avatar
Vette XP
Probably the jet air pump that runs for just a few minutes after startup. Something to do with emissions, if I remember correctly; been awhile since it has come up on the forum.
To Whining noise at startup
