Tire pressure sensor training
Old Oct 20, 2010 | 09:48 PM
mbella2000's Avatar
mbella2000
Default Tire pressure sensor training
Hello all
I just bought 4 of these sensors and I know you need some kind of a magnet to train them but can anyone tell me specifically exactly what I do to get them working with my cars computer? Do I have to retrain my key fob as well? I searched on here but all I saw were people asking questions about them I didn't fin any real directions how to train all 4. Do I install them in the rim and after the tires are put on, I just hold a magnet up to each one with the ignition on? I think there is a part on the DIC that you have to push to get it to go into sensor training? Thanks for the help!
NVM I found it finally
Originally Posted by byronhunter View Post
Tire Pressure Sensor Learn
Tools Required
J 41760 Tire Pressure Sensor Activating Tool
TPM Learn Mode Description
The Tire Pressure Monitor (TPM) system uses the remote control door lock receiver (RCDLR), body control module (BCM), driver information center (DIC), 4 radio frequency transmitting pressure sensors, and the serial data circuit to perform the TPM learn mode functions. The sensor learn procedure must be performed after a tire pressure sensor, or RCDLR replacement. Once the learn mode has been enabled, each of the sensors unique identification (Id) codes can be learned into the RCDLR's memory. After the RCDLR has received a sensor transmission, it sends a serial data message to the BCM to sound a horn chirp. This verifies the sensor has transmitted its Id and the RCDLR has received and learned it. The RCDLR must learn each sensor's Id in the proper order to determine sensor location. The first learned Id is assigned to the left front location, the second to right front, the third to right rear, and forth to left rear.
Sensor Functions
Each sensor has am internal magnetic reed switch. When the J 41760 sensor activating tool is held close to the sensor, the reed switch closes, activating the sensor. The sensor responds to a magnetic activation by transmitting in learn mode. When the RCDLR receives a learn mode transmission while in TPM learn mode, it will assign that sensor Id to the location on the vehicle relative to the order in which it was learned.
TPM Learn Mode Cancellation
The RCDLR will cancel the TPM learn mode if the ignition is turned OFF, more than 1 minute has passed and no sensor Ids have been learned, or if more than 5 minutes have passed for the entire procedure. If the learn mode is cancelled before any sensor Ids are learned, the RCDLR will remember all previously stored Ids and their locations. As soon as the RCDLR learns the first sensor Id, all previously stored Ids are erased from the RCDLR's memory.
Turn ON the ignition, with the engine OFF.
Press the DIC RESET button in order to clear any warning messages.
Press and release the OPTIONS button until the display is blank.
Press and hold the RESET button for 3 seconds.
Important
If the DIC does not display the TIRE TRAINING message, ensure the TPM option is enabled in the RCDLR. Refer to Scan Tool Output Controls .
Press and release the OPTIONS button until TIRE TRAINING is displayed.
Press and release the RESET button and LEARN L FRONT TIRE is displayed, verifying the mode has been enabled.
Important
If a horn chirp does not sound after 15 seconds, remove then reinstall the sensor activating tool.
Starting at the left front sensor, hold the J 41760 over the valve stem until a horn chirp sounds.
After the horn chirp sounds, proceed as in step 7 for the next 3 sensors in the following order:
Right front
Right rear
Left rear
Turn the ignition OFF to exit the learn mode.
Old Oct 20, 2010 | 10:49 PM
Sargechris's Avatar
Sargechris
I just used magnets from Home Depot... this may help (read thru the post):
http://forums.corvetteforum.com/1574368609-post22.html
