Have a Quick Question??????????
Old Oct 21, 2010 | 04:58 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
Default Have a Quick Question??????????
I have not driven my 04 Z since I changed the oil last November. Do I need to change it since it has been a year, or am I good?
Old Oct 21, 2010 | 05:25 PM
jrose7004's Avatar
jrose7004
I would.
Old Oct 21, 2010 | 09:41 PM
Paul 75 L82's Avatar
Paul 75 L82
I've never liked year old oil.
Old Oct 21, 2010 | 11:34 PM
MG RED 99's Avatar
MG RED 99
Oil is probably fine, the gas would be more of a concern. I assume you put some gas stabilizer in before storing it
Old Oct 22, 2010 | 04:26 PM
manley845's Avatar
manley845
Let's assume an oil change costs about $40
That comes out to 11 cents a day to protect your engine if you change the oil annually. Not too sabby in my book, and certainly well worth changing even if you haven't put many miles on it.
Sitting is the worst thing for a car, and chances are that you've driven it at least a little bit or at the absolute least I'm sure you've started it and let it run as some form of preventative maintenance.
All of this will equate to blow-by and acid to accumulate in the oil, as well as condinsation if you haven't driven at operating temp for extended periods of time.
Leave it in or change it, probably doesn't really matter. But, my vote is to change it. (if you have to ask, you must know the answer )
Old Oct 23, 2010 | 04:13 AM
BlackRocket's Avatar
BlackRocket
Seeing that you live in Indiana which is relatively humid in the summer and damp in the winter I would get it out. The crankcase breathes and the moisture is probably down in the pan what little there may be. I would change it to be safe
Old Oct 23, 2010 | 10:52 AM
slacker1201
Thanks everyone! I figured it doesn't hurt to change it, I just wanted to ask the pros. I do add stabil to all my vehicles during winter storage.
Old Oct 23, 2010 | 11:17 AM
imavettegirl's Avatar
imavettegirl
i would get it up to operating temperature first.
then i would change it.
then check ALL fluids including the brake and clutch fluids.
Old Oct 23, 2010 | 12:04 PM
dbaker's Avatar
dbaker
Changing cold oil is not something I like to do.Don't forget the filter!!!
\db2
carolina
To Have a Quick Question??????????
