Which MAF?
Old Oct 22, 2010 | 01:07 PM
DBRASUE's Avatar
DBRASUE
Default Which MAF?
I recently swapped out my LS1 for a LS6. I am using the LS1 MAF now but do I need an LS6 MAF? or are they the same? Still have the stock air box too. Thanks!
Old Oct 22, 2010 | 01:17 PM
manley845's Avatar
manley845
What year is your car? If you have a 97-00 I'd say upgrade to the larger MAF found on 01-up Vettes. You will need a wire harness adapter as the newer MAF has the AIT sensor intergrated.
If you have an 01-up already and the MAF has the intergrated AIT (identified by a 5-pin connector vs a 3-pin) then you're good to go.
I think this is right
Old Oct 22, 2010 | 01:25 PM
DBRASUE's Avatar
DBRASUE
Thanks! appreciate the quick reply!
Old Oct 22, 2010 | 01:35 PM
manley845's Avatar
manley845
No problem
Sure beats doing actual work here at the office
Old Oct 22, 2010 | 02:05 PM
armycopter's Avatar
armycopter
No problem
Old Oct 22, 2010 | 02:13 PM
99C5JA1's Avatar
99C5JA1
The MAF table from an '01+ car will need to be flashed into the PCM as well.
To Which MAF?
