Check Engine light won't come on
Old Oct 26, 2010 | 09:28 AM
whtcorv2k's Avatar
whtcorv2k
Originally Posted by dgrant3830
I believe the lamp is a standard 194 and it connects via the circuitry on the rear of the IP Cluster therefore a stereo installation should not have anything to do with it. You'll need to remove the cluster to get to the lamp. Its not that hard. You'll need to remove the center console, then the surround for the IP Cluster, knee bolster and etc. Remove the large nuts holding the steering column up in place which will allow it to lower about an inch or so which is just enough to clear the steering wheel. You can then unplug the connector on the left rear side of it. Second small ribbon connector at the top for the HUD if you are equipped with a HUD. Once out, keep the IP Cluster standing up in its normal position as the gauges are fluid filled. If you replace the one lamp, replace them all in there...there are only a few.
Thanks very much, I printed your instructions and will get some of those bulbs and proceed!
Old Oct 26, 2010 | 03:17 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm not positive about the 194 lamp but I think its correct...just not sure.
Old Oct 26, 2010 | 03:35 PM
whtcorv2k's Avatar
whtcorv2k
The dash is all apart and the bulb is smaller than a 194 but the parts house matched it with no problem. It should be back together tomorrow and thanks for your help!
Old Oct 26, 2010 | 05:10 PM
dgrant3830's Avatar
dgrant3830
Use a DVM in the ohm meter mode and verify its really bad.
Old Oct 27, 2010 | 08:26 AM
whtcorv2k's Avatar
whtcorv2k
Will do, thanks!
Old Oct 27, 2010 | 09:36 AM
wayne_69_427's Avatar
wayne_69_427
Originally Posted by PEERPSI
Burnt out light bulb?
Never over look the obvious
Old Oct 27, 2010 | 09:48 AM
whtcorv2k's Avatar
whtcorv2k
Absolutely, and if it was easier to replace, it would have been done in the first minute. You should see all of my dash and console laid out all over the place just to replace a bulb smaller than half a pinky fingernail. On the bright side, it lasted 10 years before going out..... I was convinced it was related to the stereo replacement but I guess it was wishful thinking.
Old Oct 27, 2010 | 06:00 PM
m6 c5's Avatar
m6 c5
So can we assume you have it back together and working now?
Old Oct 27, 2010 | 06:40 PM
whtcorv2k's Avatar
whtcorv2k
Yes, thanks, completed late this afternoon, the bulb was the final fix for the check engine light and while it was apart, replaced the bulb for the bottom two switches on the Driver Information switches, and while the dash was all apart, found the rattle that was driving me crazy. Thanks to all for your help on this!
Old Oct 27, 2010 | 07:08 PM
m6 c5's Avatar
m6 c5
At least it was something relatively simple and an inexpensive fix.
Old Oct 27, 2010 | 09:14 PM
dgrant3830's Avatar
dgrant3830
Cool!
Old Oct 29, 2010 | 01:22 PM
whtcorv2k's Avatar
whtcorv2k
Yes, you're right there. I do have one lingering problem though. Before the dismantling of the dash, my HUD gas gage matched the needle gas gage on the dash. Now, after reassembly, it just fluctuates between about 2/5 and 3/5 (3 blocks to 5 blocks illuminated) of a tank. Even though I topped it off to a full tank. I cleared all the DTC codes thinking one of them had it confused. No help from doing that. Any ideas on what I did or, better yet, how to correct it? Thanks!
Old Oct 29, 2010 | 03:22 PM
  #33
dgrant3830's Avatar
dgrant3830
I'm thinking either the main IP Cluster cable connector isn't quite secure or the hud connector that came off the top of it, isn't quite all the way on.
Old Oct 29, 2010 | 04:12 PM
  #34
whtcorv2k's Avatar
whtcorv2k
Both are very good suggestions. I think it might be a little more "self inflicted". I think I might have hit the page button at some point and it was showing something else on that right side. Maybe oil pressure or something. I was just going through the page and brightness on the hud and happened to look at it and saw it was reading full gas. Cheesh. Once again, I overlooked what should have been obvious. Thank you!
Old Oct 29, 2010 | 04:40 PM
  #35
dgrant3830's Avatar
dgrant3830
I agree with you there. Looking at the wrong page will throw you for a quick loop there. Hey, I've done that too so no worries.
