misfire in #8
Old Oct 25, 2010 | 04:11 PM
vette29209's Avatar
vette29209
Default misfire in #8
hey guys...! i got a 98 vette, and got a misfire in the # 8. just changed my plugs 2 weeks ago. do you think my plug is bad or the coil..????
Old Oct 25, 2010 | 04:49 PM
dougbfresh's Avatar
dougbfresh
How did you determine #8??
Old Oct 25, 2010 | 10:07 PM
robsc501's Avatar
robsc501
Hi There,
I would like to hear the how the determination was made.
robsc501
Old Oct 25, 2010 | 10:16 PM
TN Vette's Avatar
TN Vette
Check the plug wire first. I just had a new one fail in about 300 miles, the wire connection inside the crimp at the spark plug side broke.
Did you get a code from the DIC to point you to #8?
Old Oct 26, 2010 | 07:03 AM
vette29209's Avatar
vette29209
well I went to autozone because my check engine light came on. there scanner told me it was my #8 misfire.
I went home and when I went to pull the plug I found the spark plug wire had popped off. thank goodness it was only that...! thanks for your help guys..!
To misfire in #8
