turn signal/hazard flasher
Old Oct 26, 2010 | 04:53 PM
showlow's Avatar
showlow
Default turn signal/hazard flasher
can anyone tell me where i might locate the flasher for the turnsignal and hazard. are they one in the same or are they seperate ? owners manuel shows where the fuse is, but not the flasher itself. thanks loads
Old Oct 26, 2010 | 05:07 PM
ICUALL's Avatar
ICUALL
Default Same
The turnsignal/flasher is part of the Hazard switch in the dash.
Old Nov 16, 2010 | 01:43 AM
GRNNREG's Avatar
GRNNREG
Default Good "Map"
This will help you find it: http://www.ls1howto.com/index.php?article=24
Old Nov 16, 2010 | 01:08 PM
RSchleder's Avatar
RSchleder
slowlow
Assuming your having a intermittent problem with your turn signals, I'd suggest a "bi-pass flasher cable" in lieu of replacing the hazard switch. The bi-pass cable takes 20 minutes and cost about $60 and you issues will be behind you. Several vendors here sell them, Corvettes of Houston being one of them if I remember correctly. Good luck, Ron
To turn signal/hazard flasher
