read the sticky on grounds
Old Oct 26, 2010 | 07:20 PM
z06 vett's Avatar
z06 vett
Default read the sticky on grounds
i read all i can find and it's time to get help,
after a drive line R&R the car would not start.indicators were low oil level on display ,no fuel pressure but could hear pump,no codes.ran it down to the ground wire behind the left head was broken.re-grounded the fuel pressure sender i use for pressure gage.started and ran a few times without issue.then after a run ,on stands to 180* or so it died. restarted Sunday,ran for a while and will not start again.charger has stayed on,no codes ,good fuel pressure.no spark to wires.
i have the service manuals but no tech 2.not much help.it has to be something simple,i even loaded and unloaded the tune and that worked fine.scanned with on board,autoxray and diablo u7193.i even have a data log i ran to fix a o2 sensor .
mike
Old Oct 26, 2010 | 07:29 PM
TN Vette's Avatar
TN Vette
I remember reading somewhere that there is a ground for the coils on the back of the engine possibly on the driver's side?
Old Oct 27, 2010 | 12:37 AM
Bluefire's Avatar
Bluefire
When I swapped out my diff for 3:42's I had an issue with the ground in the left rear wheel well. It set off like 12 codes and ran like crap. Check that. Also, when I had lowered my driveline/back end of motor so much to get the TT out that the accordian tube on my intake had come loose causing a rough idle and dying.
Good Luck
Old Oct 27, 2010 | 01:54 PM
z06 vett's Avatar
z06 vett
i think that one is a harness ground?it was the one we fixed
thanks ,
mike
Old Oct 27, 2010 | 01:56 PM
z06 vett's Avatar
z06 vett
Good Luck
the maf wires will code but, the rear has to be looked at again .this were i grounded the pump booster.
mike
To read the sticky on grounds
