Coolant in the Knock Sensor Pocket?
Old Oct 26, 2010 | 07:23 PM
jammerjamesharmon's Avatar
jammerjamesharmon
Default Coolant in the Knock Sensor Pocket?
Yes, that is what I discovered when replacing the front knock sensor. It threads into the top of the engine, in the thread hole is coolant, but there was no thread sealer or seal on the knock sensor. Pulled the back sensor as sanity check and it has no coolant in the thread hole and no seal or thread seal either. This sensor was wasted with corrosion from the coolant. I believe this is why it is bad. Please help with why there was coolant in the pocket.
James
Old Oct 26, 2010 | 07:33 PM
ZeeOSix's Avatar
ZeeOSix
James
I thought the knock sensors screwed into the valley cover ... which shouldn't have any coolant passages in it that I know of ... ???
Old Oct 26, 2010 | 07:38 PM
jammerjamesharmon
No not the cover. The cover is the pocket which was full of coolant. The sensor goes through the cover. There is a big rubber seal to keep the oil out, but where the knock sensor threads into has coolant on the front sensor any way.
Old Oct 26, 2010 | 07:42 PM
ZeeOSix's Avatar
ZeeOSix
So the knock sensors screw into a coolant passage? ... must be if the knock sensor threads leaked coolant. I can't see why there would be any coolant near the knock sensor hole. Guess I'm not up on the layout.
To Coolant in the Knock Sensor Pocket?
