Link for M6 removal
Old Oct 27, 2010 | 12:30 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Link for M6 removal
Does anyone have a link that covers M6 removal?
Old Oct 27, 2010 | 12:50 PM
dougbfresh's Avatar
dougbfresh
Do a search, covered several times.
Old Oct 27, 2010 | 05:29 PM
robsc501's Avatar
robsc501
Hi There,
This is what your looking for. Do it on a lift un- less you have a strong back.
http://redshift.homestead.com/drivetrain1.html
robsc501
Old Oct 27, 2010 | 09:34 PM
PEERPSI's Avatar
PEERPSI
PM email address and I'll send you the version with pictures.
Disconnect the negative battery cable.
Remove the console. Refer to Console Replacement in Instrument Panel, Gages and Console.
Carefully pry off the shift control **** button.
Pry the shift control **** retainer out of the slots and remove the retainer.
Unscrew the shift control ****.
Grasp the sides of the shift control boot and apply light pressure in toward the shift control lever to begin to release the shift boot retaining tabs from the IP accessory trim plate.
Using light pressure, continue to release the remaining boot retaining tabs.
Lift the boot away from the trim plate and remove the boot.
Remove the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory in Instrument Panel, Gauges and Console.
Remove the shift control closeout boot retaining nuts.
Remove the shift control closeout boot.
Remove the shift control assembly. Refer to Shift Control Assembly Replacement .
Remove the left IP lower insulator panel. Refer to Closeout/Insulator Panel Replacement - Left in Instrument Panel, Gauges and Console.
Remove the clutch master cylinder pushrod retainer.
Disconnect the clutch master cylinder pushrod from the clutch pedal.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the clutch actuator cylinder hose from the hose retaining clip (at the rear of the engine).
Using the J 42371 , depress the white circular release ring on the actuator cylinder hose and simultaneously pull lightly on the master cylinder hose to disconnect.
Protect both hose coupling ends from dirt and damage.
Remove the rear tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the catalytic converter. Refer to Catalytic Converter Replacement in Engine Exhaust.
Tie off the muffler assemblies to the underbody to support out of the way.
Remove the driveline tunnel closeout panel. Refer to Driveline Tunnel Closeout Panel Replacement in Propeller Shaft.
Remove the rear transverse spring. Refer to Rear Transverse Spring Replacement in Rear Suspension.
Support the lower control arm with a straight jack.
Disconnect the outer tie rod end from the suspension knuckle. Refer to Tie Rod Replacement in Rear Suspension.
Remove the shock absorber lower mounting bolt.
Disconnect the lower ball joint from the suspension knuckle. Refer to Knuckle Replacement in Rear Suspension.
Remove the straight jack from the control arm.
Repeat steps 25 through 29 for the other side of the vehicle.
Assemble the J 42055 .
Install the J 42055 to a transmission jack.
Position and firmly secure the J 42055 with the transmission jack to the transmission.
Disconnect the wiring harness and brake pipe clip retainers from the rear suspension crossmember.
Remove the differential to transmission lower nut. (Removing the nut at this time will aid in separating the differential from the transmission after the driveline has been removed from the vehicle.)
Remove the transaxle mount to rear crossmember nuts.
Position a transmission jack under the rear suspension crossmember and firmly secure the crossmember to the jack.
Using ONLY HAND TOOLS, remove the rear suspension crossmember retaining nuts.
With the aid of an assistant, slowly lower the rear suspension crossmember away from the vehicle frame rails and remove the crossmember.
Remove the transaxle mount bracket to differential bolts.
Remove the transaxle mount with bracket. (Removing the transaxle mount will allow for greater stability on a workbench after the driveline is removed.)
Using a pry bar, CAREFULLY release the axle shafts from the differential.
Tie off the axle shafts (1) to the underbody to support out of the way. The muffler assembly pipes toward the rear offer a good location to help support the axle shafts (1).
Release the retainer (1) securing (and positioning) the wiring harness to the L-shaped brackets along the driveline support assembly, then slide the harness up out of the brackets and position out of the way.
SLOWLY lower the driveline approximately 5 cm (2 in), while simultaneously adjusting the angle of tilt, in order to access the electrical connectors.
Disconnect the vehicle speed sensor (VSS) electrical connector.
Disconnect the wiring harness retainer from the stud at the differential rear cover.
Disconnect the wiring harness retainer clip from the top of the differential.
Disconnect the backup lamp switch electrical connector.
Disconnect the reverse lockout solenoid electrical connector.
Disconnect the gear select (skip shift) solenoid electrical connector.
Disconnect the transmission fluid temperature sensor electrical connector, if equipped.
Insert a putty knife, or similar tool, between the edge of the shifter bracket on the side of the driveline support assembly and the brake pipe retainer on the wall of the driveline tunnel.
SLOWLY lower the driveline, while simultaneously adjusting the angle of tilt, and observe the relationship between the top rear of the differential and the lowest part of the rear compartment panel floor (the center storage compartment between the frame rails); the differential should not be lowered more than approximately EVEN with the specified body point of reference. (The engine positive crankcase ventilation (PCV) pipes which route along the rear of the engine intake manifold will likely contact the dash panel.)
Release the wiring harness from the harness retainer along the top of the transmission.
Check to be sure that the wiring harness is free from the driveline being removed.
Using a block of wood to protect the engine oil pan, place a straight jack under the rear of the engine oil pan to support the engine from stressing the composite dash panel.
Remove the five driveline support assembly to engine flywheel housing bolts.
Carefully bend the wiring harness bracket away from the driveline toward the driveline tunnel wall in order to make a clear removal path for the driveline.
Important
The aid of an assistant will be necessary for the remaining steps.
Have an assistant insert a flat bladed screwdriver, or similar tool, between the edge of the driveline support assembly and the engine flywheel housing, then begin to pry the driveline loose from the engine.
Have an assistant guide the front of the driveline during the removal of the driveline from the vehicle.
SLOWLY lower the driveline, while simultaneously adjusting the angle of tilt and pulling the driveline away from the engine UNTIL the propeller input shaft at the front of the driveline support assembly just clears the engine flywheel housing.
SLOWLY lower the driveline completely out of the vehicle.
Position the chainfall, or equivalent, of a lift device in a way which will protect the rear exhaust hangers located on the driveline support assembly.
Using the lift device, raise the driveline to relieve the weight from the transmission jack.
Disconnect the J 42055 from the transmission jack ONLY; the J 42055 will provide stability to the driveline components while working on a bench.
Position the driveline on a workbench with the lift device still attached.
Support the driveline support assembly and the differential for additional balance.
Remove the lift device from the driveline.
Remove the transmission to driveline support assembly bolts/studs.
Insert a flat bladed screwdriver, or similar tool, between the edge of the driveline support assembly and the transmission, then begin to pry the driveline support assembly loose from the transmission.
Slowly slide the driveline support assembly away from the transmission while guiding the transmission shift rod through the opening in the driveline support assembly.
Using a drift or punch, remove the roll pin (1) retaining the transmission shift rod to the transmission shift shaft.
Remove the transmission shift rod.
Remove the differential to transmission bolts and nuts.
SLOWLY slide the differential from the transmission.
Remove the transmission from the J 42055 , if necessary.
Installation Procedure
Notice
When tilting down the rear of the driveline, insert a putty knife or similar tool between the shift control bracket on the driveline support assembly and the brake pipe retainer on the driveline tunnel wall to prevent damage.
Notice
Ensure that the clutch hydraulic hoses are positioned away from nearby vehicle components or vehicle damage may result.
Install the transmission to the J 42055 , if removed.
SLOWLY slide the differential to the transmission.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the differential to transmission bolts and nuts. Tighten
Tighten the differential to transmission bolts and nuts to 50 N·m (37 lb ft).
Install the transmission shift rod to the transmission shift shaft.
Using a drift or punch, install the roll pin (1) to retain the transmission shift rod to the shift shaft.
Slowly slide the driveline support assembly to the transmission, while guiding the transmission shift rod through the opening in the driveline support assembly.
Install the transmission to driveline support assembly bolts/studs. Tighten
Tighten the transmission to driveline support assembly bolts/studs to 50 N·m (37 lb ft).
Loosely install a rubber band onto the transmission shift rod and position just behind the shift rod clamp. (The rubber band will be used to aid in installing the shift control assembly after the driveline has been installed.)
Using a piece of masking tape, or similar tape which can be easily broken, affix the transmission shift rod to the driveline support assembly and position the rod just to the outside of the mounting boss used for the shift control. (The tape is intended to keep the shift rod in position to aid in shift control installation after the driveline has been installed.)
Important
The aid of an assistant will be necessary for the following steps until the driveline is installed into the vehicle.
Using the lift device, raise the driveline off the workbench and position the driveline with the J 42055 onto a transmission jack.
Connect the J 42055 to the transmission jack.
Position the driveline under the vehicle.
Begin to raise the driveline at the approximate angle used during removal.
Position the wiring harness along the driveline support assembly and LOOSELY install the harness into the harness retaining slots.
Have an assistant guide the front of the driveline so the propeller input shaft is just to the rear of the engine flywheel housing, then raise the driveline to the PROPER HEIGHT and the PROPER ANGLE to install to the engine.
Have an assistant begin to insert the propeller input shaft into the clutch driven plate hub while maintaining the proper angle of the driveline; if necessary, use a screwdriver to rotate the shaft slightly to bring the splines into alignment.
SLOWLY seat the driveline to the engine flywheel housing while maintaining the proper angle of the driveline.
Reposition the wiring harness bracket from near the driveline tunnel wall to align with the appropriate driveline support assembly bolt hole.
Install the five driveline support assembly to engine flywheel housing bolts. Tighten
Tighten the driveline support assembly to engine flywheel housing bolts to 50 N·m (37 lb ft).
Install the wiring harness to the wiring harness retainer along the top of the transmission.
SLOWLY raise the driveline to approximately 5 cm (2 in) BELOW the final installed height.
Connect the transmission fluid temperature sensor electrical connector, if equipped.
Connect the gear select (skip shift) solenoid electrical connector.
Connect the reverse lockout solenoid electrical connector.
Connect the backup lamp switch electrical connector.
Connect the wiring harness clip to the top of the differential.
Connect the wiring harness retainer to the stud at the differential rear cover.
Connect the vehicle speed sensor (VSS) electrical connector.
Slowly raise the driveline to final installation height.
Remove the putty knife, if still in position.
Remove the jack which supported the rear of the engine.
Remove the tie-off retainers from the axle shafts.
CAREFULLY align and seat the axle shafts to the differential.
Install the transaxle mount with bracket to the differential.
Install the transaxle mount bracket to differential bolts. Tighten
Tighten the transaxle mount bracket to differential bolts to 50 N·m (37 lb ft).
With the aid of an assistant, begin to raise the rear suspension crossmember (still firmly attached to a transmission jack), to the vehicle frame rails.
Guide the rear suspension crossmember alignment pins into the alignment holes in the vehicle frame rails, and guide the transaxle mount studs into the mounting holes in the crossmember, then raise the crossmember to seat to the frame rails.
Using ONLY HAND TOOLS, install NEW rear suspension crossmember mounting nuts. Tighten
Tighten the rear suspension crossmember mounting nuts to 110 N·m (81 lb ft).
Remove the transmission jack from the rear suspension crossmember.
Release the J 42055 from the transmission, then remove the J 42055 and transmission jack.
Install the transaxle mount to rear suspension crossmember nuts. Tighten
Tighten the transaxle mount to rear suspension crossmember nuts to 50 N·m (37 lb ft).
Install the differential to transmission lower nut. Tighten
Tighten the differential to transmission lower nut to 50 N·m (37 lb ft).
Connect the wiring harness and brake pipe clip retainers to the rear suspension crossmember.
Connect the lower ball joint to the suspension knuckle. Refer to Knuckle Replacement in Rear Suspension.
Install the shock absorber lower mounting bolt. Tighten
Tighten the rear shock absorber lower mounting bolt to 220 N·m (162 lb ft).
Connect the outer tie rod end to the suspension knuckle. Refer to Tie Rod Replacement in Rear Suspension.
Remove the straight jack from the suspension control arm.
Repeat steps 46 through 50 for the other side of the vehicle.
Install the rear transverse spring. Refer to Rear Transverse Spring Replacement in Rear Suspension.
Carefully pull the wiring harness down into the L-shaped brackets along the driveline support assembly, align the harness retainer (locator) (1) to the hole in the forward bracket, then secure in place.
Important
DO NOT rely on an audible click or a visual verification of the clutch hydraulic hose quick connect fitting connection.
Connect the clutch actuator cylinder hose to the clutch master cylinder hose. Push together the clutch hydraulic hose quick connect fittings, then pull back on the fittings to verify engagement.
Check the clutch hydraulic hoses for twists or kinks.
Install the clutch actuator cylinder hose to the hose retaining clip (at the rear of the engine).
Install the driveline tunnel closeout panel. Refer to Driveline Tunnel Closeout Panel Replacement in Propeller Shaft.
Remove the tie-off retainers from the muffler assemblies.
Install the catalytic converter. Refer to Catalytic Converter Replacement in Engine Exhaust.
Install the rear tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Lower the vehicle.
Connect the clutch master cylinder pushrod to the clutch pedal.
Install the clutch master cylinder pushrod retainer.
Install the left IP lower insulator panel. Refer to Closeout/Insulator Panel Replacement - Left in Instrument Panel, Gages and Console.
Grasp the transmission shift rod and pull up to break the masking tape installed earlier to maintain position during installation.
Stretch the rubber band, while still installed onto the transmission shift rod, over the rear stud on top of the driveline tunnel to aid in shift control installation.
Install the shift control assembly. Refer to Shift Control Assembly Replacement .
Break and remove the rubber band.
Install the shift control closeout boot. Check that the closeout boot fully seats to the shift control lever seal and the base of the shift control assembly (1).
Install the shift control closeout boot retaining nuts. Tighten
Tighten the shift control closeout boot retaining nuts to 12 N·m (106 lb in).
Install the IP accessory trim plate. Refer to Trim Plate Replacement - Instrument Panel (I/P) Accessory in Instrument Panel, Gages and Console.
Install the shift control boot over the shift control lever.
Align the shift control boot to the IP accessory trim plate opening, then press to lock the boot retaining tabs.
Adjust the shape of the boot for appearance, if necessary.
Screw the shift control **** onto the shift control lever until the **** bottoms out.
Unscrew the shift control **** just enough to align the retainer slot with the slot on the shift control lever.
Install the shift control **** retainer (1) into the slots and seat fully.
Install the shift control **** button.
Install the console. Refer to Console Replacement in Instrument Panel, Gages and Console.
Connect the negative battery cable. Tighten
Tighten the negative battery cable bolt to 15 N·m (11 lb ft).
Program the transmitters. Refer to Transmitter Programming in Keyless Entry.
Bleed the clutch hydraulic system. Refer to Hydraulic Clutch Bleeding in Clutch.
Old Oct 28, 2010 | 09:00 AM
Hvymtlc5's Avatar
Hvymtlc5
Thanks - very detailed.
Can I get the differential out without removing the torque tube and tranny?
Same question for tranny...does the torque tube need to come out?
not sure what broke yet....
Old Nov 12, 2010 | 04:35 PM
ndavis296's Avatar
ndavis296
Default what broke?
Just curious if you've gotten it out yet and whats broke? I swapped my M6 out in sept. Lengthy process but the work wasn't overly hard I thought although there was 2 of us doing it. This is what I used:
http://forums.corvetteforum.com/c5-t...sion-swap.html
To Link for M6 removal
