Having issues after giving someone a jump start...??
Old Oct 27, 2010 | 05:42 PM
00Corvette's Avatar
00Corvette
Default Having issues after giving someone a jump start...??
Guys,
The other day my fiances Accord was having issues starting up, it's a consistent thing that only happens in the morning when the car is cold.
In order to get the car to start, it has to crank over for a WHILE. So long that it completely ran her battery down where the car would not crank over anymore.
I decided to hook up some jumper cables, let the Vette run and charge up the Honda battery for a bit( Optima red top still in Vette).
Then the Honda still needed a good full minute of cranking off of the Vettes battery in order to start up.
Ever since then, each time that I shut my car off..it seems to lose it's "sync".
If I leave the DIC on say "miles to empty" feature...each time that I re-start the car it's back on "odometer"??
This morning when I went to go to work...I got nothing but a big "click" and no crank or lights on the dash.
After a couple more tries just turning the key, I was able to get the lights on the dash to come on(still hearing the "click" each time I tried to start it).
Pulled the codes and I came up with a C 1255 H C...
So I turned the key back off, tried again and the car cranked over and fired.
The C 1255 turned into an "H" code, all of my stereo presets and clock had been lost but the car started and I was able to clear the code.
Just went out to drive home for lunch, car fired right up, no codes but it still lost my presets and the DIC was back on odometer...
I'm all ears for any ideas..
Thanks in advance,
Donnie
Old Oct 27, 2010 | 06:04 PM
Dave1998's Avatar
Dave1998
Your solution is to take the Honda to a shop and get it fixed!
Why put up with that
Old Oct 27, 2010 | 06:33 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by 8VETTE7
.....The Red tops are marginal for having the reserve cranking amps to meet the C5 battery specs. If that is down somewhat you will see the symptoms you are experiencing.
I would agree, especially since it appears that the Honda's battery was pretty well down on charge, and you were using the Optima as a "buffer", to pump up the Honda. You may have damaged the Optima...
Old Oct 27, 2010 | 08:26 PM
Bill Dearborn's Avatar
Bill Dearborn
What does your voltmeter read? I have known people who took out their alternator when jumping somebody else's car.
Bill
Old Oct 27, 2010 | 08:32 PM
tom01ss's Avatar
0tom01ss
Former Vendor
i would load test the batter on the honda , use an inductive pickup clam and check the max load on the alt. if all checks out i would look and fuel circuit and ignition system. y go to the shop so easy to fix
Old Oct 27, 2010 | 09:12 PM
Jewjenk's Avatar
Jewjenk
Due to the computers in cars now, I do not jump start anyone.............
That is why I have a jump battery pack and a sears charger capable of jump starting a car..................................... ..................
Old Oct 27, 2010 | 11:40 PM
00Corvette's Avatar
00Corvette
Bill
It still reads 13.1-13.4 just off of idle.
And I don't need help with the Honda guys..I've already been through everything over on the Honda forum.
I'll have the battery load tested, thanks for the advice just didn't want to make sure I didn't take something out by cranking the car over like that.
To Having issues after giving someone a jump start...??
