Help With Tranny Issue
Old Oct 30, 2010 | 04:05 PM
mikes1000rr's Avatar
mikes1000rr
Default Help With Tranny Issue
Hey guys,
Lately my Vette (m6 2001 106kmi) has been having problems with second gear. Before I started having current problem it would just pop out of gear once in a while.
Currently I cannot get the car to shift into 2nd very often Ive tried to start off in second gear and shift it easily, quickly all it does it either grind even with clutch in or some times it kinda feels like it sits in but when i start letting the clutch out it starts grinding. Ive also tried holding it in place but that doesnt seem to help so I am not thinking its a syncro(sp?).
Old Oct 30, 2010 | 04:28 PM
ragtopws6's Avatar
ragtopws6
The most likely cause for popping out of gear is the broken plastic fork pads. Over time they get brittle and break. The fork doesn't engage the synchro ring all the way into the engagement tooth and ends up popping back out. Only fix? Rebuild it and replace them with bronze pads.
Originally Posted by mikes1000rr
Hey guys,
Old Oct 30, 2010 | 04:57 PM
mikes1000rr
Well yes that is no longer the only symptom the car is having. Now it wont even go into the gear with out massive grinding.
Old Oct 30, 2010 | 05:02 PM
imavettegirl's Avatar
imavettegirl
time to pull trans and find out what is really wrong and fix it.
it does sound like the shift forks.
i hope you stopped driving it.
Old Oct 30, 2010 | 05:17 PM
mikes1000rr
havent stopped driving it no..,.only form of transportation.
Old Oct 30, 2010 | 07:14 PM
mikes1000rr
Would the shift forks even cause it to grind with the clutch engaged (pressed in)
Old Oct 30, 2010 | 07:37 PM
mikes1000rr
Ok. I just talked to a shop (over the phone) he asked me to try to shift it into gear with the car not running. And it does indeed seem to get into gear no problem. he seems to think it might be a clutch issue?
Old Oct 30, 2010 | 07:42 PM
TN Vette's Avatar
TN Vette
A clutch issue usually wouldn't just be isolated to one gear.
Old Oct 30, 2010 | 07:54 PM
mikes1000rr
Thats what I thought too.. Just I'm def not a mecahnic.. Just a guy trying to figureout how to get his Vette outta the sickhouse.
Old Oct 30, 2010 | 08:26 PM
ragtopws6's Avatar
ragtopws6
Take a look at the pics below. It's the 1-2 shift fork WITHOUT the plastic fork pads. When you shift into 2nd gear the fork is at the end of its travel but with the pads the synchro ring is NOT engaged all the way. The 3rd picture is what's left of the 1-2 fork pad.
Old Oct 30, 2010 | 08:45 PM
ragtopws6's Avatar
ragtopws6
This is 5-6 shift fork but you get the idea......
Old Oct 30, 2010 | 09:30 PM
mikes1000rr
So that gap is why once in a while it will shift into gear?
Old Oct 30, 2010 | 09:54 PM
ragtopws6's Avatar
ragtopws6
Correct. I have heard when shifting into that gear with force, it will go into gear without grinding but that is from inertial forces. Bottom line, you have to pull the trans and open it up.
Old Nov 1, 2010 | 08:35 PM
mikes1000rr
When it does go into gear though It isn't done with force... some times it just goes in nice and smooth. Some days its different... today it was a 80%/20% chance of going into gear yesterday it was a 0%/100% to go into gear. I just wanna cover all my bases before I try to play with the transmission since I have no idea what to do with it.
Old Nov 1, 2010 | 08:54 PM
ragtopws6's Avatar
ragtopws6
If you have grinded that gear enough times, that could exacerbate the issue. You will need at least 2nd gear and 1-2 synchro, possibly the blocking rings/cones also.
Old Nov 5, 2010 | 04:10 PM
mikes1000rr
still trying to get this figured out for those of you who have tuned in =) Ragtop also thank you for your offer.
To Help With Tranny Issue
