HUD Problem
Old Nov 1, 2010 | 04:54 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default HUD Problem
Any fix for a HUD not lighting up. I know about the broken pin fix if it doesn't move up or down. This one just doesn't light.
Old Nov 1, 2010 | 07:44 PM
FirethornC5's Avatar
FirethornC5
Probably needs to be diag'ed. I'd probably start with the HUD dimmer switch.
Other than that my other guess's would be the matrix display in the HUD projector or worse case the cluster.
Do you know someone that you could possibly swap a known good switch, projector or cluster with?
Definitely needs to be troubleshot.
Good luck!
Old Nov 2, 2010 | 08:12 AM
Corvette ED
I donot think it is the switch because I can see the mirror moving when I press the button to move it up and down.
Old Nov 2, 2010 | 12:58 PM
FirethornC5
The slide is what controls the brightness of the HUD display. Maybe that portion of the switch or wiring is bad?
Just a guess.
To HUD Problem
