clutch switch
Old Nov 1, 2010 | 06:01 PM
rich65's Avatar
rich65
Default clutch switch
Hi. my check engine came on and auto zone checked it and it says clutch switch circut failure. Anybody have this problem and is it just a matter of changing the switch? Thanks
Old Nov 1, 2010 | 07:59 PM
rich65's Avatar
rich65
Well I replaced the switch and no luck still has check engine light,so i'm open for some ideas. I'm LOST
Old Nov 1, 2010 | 08:20 PM
Paul 75 L82's Avatar
Paul 75 L82
Read the codes yourself and post the code here.
Old Nov 8, 2010 | 04:36 PM
rich65's Avatar
rich65
Code came back on and heres the number p0704 hc. Clutch switch circut. Already replaced the switch and code came back on so help me please. Thanks
Old Nov 8, 2010 | 10:01 PM
rich65's Avatar
rich65
Is it possible i got a faulty switch or is there something else going wrong?
Old Nov 8, 2010 | 11:32 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
Is it adjusted correctly?
Old Nov 8, 2010 | 11:42 PM
rich65's Avatar
rich65
How do you adjust? I do have a tick master cylinder.
Old Nov 9, 2010 | 04:06 PM
TickPerformance's Avatar
0TickPerformance
Former Vendor
The upper switch gets triggered when the clutch pedal is at the top of its travel. If the pedal itself is set lower than factory with our master you will have to screw the switch down in order for it to make contact with the pedal again. Its pretty easy, just unplug the wire...screw the switch down until its piston is pressed in good, then plug the wire back up.
Old Nov 9, 2010 | 10:22 PM
rich65's Avatar
rich65
Would the cruise control switch cause a check engine light that says cluch switch 0704?
To clutch switch
