multifunction switch and cruise control-help!
Old Nov 2, 2010 | 08:44 PM
lwd2000's Avatar
lwd2000
Default multifunction switch and cruise control-help!
Just installed my new "used" multifunction switch to fix my instrument lights/tail lights problem. Everything works great now except.......my cruise control Not sure how the place I ordered my switch from is going to treat me even though it was advertised as in good operational order.
Anybody know anything about the switch that I might do to fix the cruise problem. It was working fine with the old switch.
Old Nov 3, 2010 | 09:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I don't have a wiring diagram for the switch handy right now but it sounds like that switch isn't working. Its sealed internally and you can't get to it to the best of my knowledge. Someone will have the schematic so you can meter the switch and verify its operation. Pull your codes while you are working on this just in case. Usually when the cruise fails to work, its the clutch switch(if MM6) and or the brake light switch on the pedals.
Old Nov 3, 2010 | 10:22 AM
rebelheart's Avatar
rebelheart
If it worked before,you most likely have a switch or connection problem.Contact your seller!
To multifunction switch and cruise control-help!
