Getting power for shift light...where?
Old Nov 2, 2010 | 10:09 PM
csilvers1984's Avatar
csilvers1984
Default Getting power for shift light...where?
I have found the group of wires under the dash for tach signal and need to know where to get a key on power source and ground. Any help would be great! Thanks!
Old Nov 3, 2010 | 12:36 AM
memphis_vette's Avatar
memphis_vette
there is the accessory wire for the ignition you can tap into and then any bare metal can be a ground
Old Nov 3, 2010 | 12:42 AM
csilvers1984
Any way of identifying this wire? I'm tackling this install tom.
Old Nov 3, 2010 | 02:34 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
There was a post on here some years ago, so do a search and you should find it. It is really good and I found the wire the first time.
I'm going from memory but I think there are 4 white wires, one of whick is smaller or a slightly different color, thats not the one. The other 3 are the same diameter but one is very slightly a different color of white, thats the one, Again do a search Take a look at the following
http://forums.corvetteforum.com/c5-t...cs.html#goto_t
Old Nov 3, 2010 | 02:54 PM
memphis_vette
hmm i forgot what color it is. my car is in the shop so i cant go take a looks. i think it is brown but it might be yellow? get a test light and that will tell you which one
Old Nov 3, 2010 | 04:08 PM
dougbfresh's Avatar
dougbfresh
If you have HUD, there is a shift indicator in the HUD display.
Old Nov 3, 2010 | 10:22 PM
csilvers1984
Yes I have HUD but I find it as a distraction,I would prefer a light.
Old Nov 3, 2010 | 10:25 PM
csilvers1984
Thanks bro
Old Nov 3, 2010 | 11:04 PM
bumble-z's Avatar
bumble-z
What year is your car? Your pro file is not filled out.
Mine is an 03. These are the instructions that I used a few years back.
I prefer using the shift light at the strip.
http://forums.corvetteforum.com/show...=619162#goto_t...
Old Nov 3, 2010 | 11:50 PM
csilvers1984
Yea I had a profile before I had a vette lol,I like the light bc there is too much going on to pay attn to a small factory indicator. Thanks for the link
Almost forgot I have a 03 Z06
Old Nov 4, 2010 | 05:55 AM
trussme's Avatar
trussme
Default location for 12V & grd.
There's a HOT and SWITCHED aux wire connector in the passengers foot well. It has 12 VDC HOT, 12 VDC Switched and GROUND. If they have never been accessed there going to be wrapped in black duct tape.Look in the foot well, remove the TOE BOARD, and you will see a big silver box (the BCM). The wires will be above the box to the left near the fire wall They will be orange, yellow and black. The wires are dead ended (not attached to any thing)
The YELLOW is ON when the key is in ACC or ON position and is served by Fuse 11 in the I/P fuse block,The ORANGE is ON at all times, and is powered off Fuse 7...The BLACK is GROUND and is grounded at G202
Old Nov 4, 2010 | 12:13 PM
skyavonee's Avatar
skyavonee
In 04 Z06's there's an accessory power wire under the steering wheel; it's the pale yellow wire in the small bundle that also includes grey, purple, pink, and sea green. I'm guessing it's the same for all other 03-04 Vette models, at the very least. I tapped into it to get the switchable power for my aftermarket head unit.
Old Nov 4, 2010 | 09:53 PM
csilvers1984
Thanks for all the help guys,I installed my shift light tonight!
Old Nov 4, 2010 | 10:18 PM
vsocks1's Avatar
vsocks1
Let's see some pictures now!
Old Nov 4, 2010 | 11:39 PM
csilvers1984
Here is a few phone pics
this is where I got key-on power(yellow) and ground(blk) orange is not used
pass footwell above BCM (has blk duct tap from factory)
after tap removed
this is where I tapped for tach signal,group of wires under driver side dash. Group has 4 white 1 larger and 3 smaller. I soldered a needle and set the shift light to a low rpm and tested each wire till I found the tach signal (kinked wire)
ok here is where I mounted the light,I might move it in the future but for now it's a good functional location.
Old Nov 5, 2010 | 01:04 AM
bumble-z's Avatar
bumble-z
I mounted my shift light on the column too. Makes it alot easier to adjust the RPM's in that location .
No need to go to pass side ft well. All the wires you need are right in the bundle where you found your tach wire.
Metal for ground can be found there too.
Nice job. Now look for even lower ET's!!
Old Nov 5, 2010 | 01:52 AM
csilvers1984
We'll see if I can set a new pb this Sunday
Old Nov 5, 2010 | 05:07 PM
vsocks1's Avatar
vsocks1
To Getting power for shift light...where?
