How do I remove the stock shifter?
Old Apr 3, 2002 | 07:14 PM
Horsepower's Avatar
Horsepower
Default How do I remove the stock shifter?
I read somewhere that someone said this was a snap. I can't seem to figure it out though. I removed 4 nuts from around the shifter but it still won't budge. I tried taking off the console piece but can't even do that. help.... :confused:
Old Apr 3, 2002 | 07:32 PM
C5Cemo's Avatar
C5Cemo
Default Re: How do I remove the stock shifter? (Horsepower)
If you're able to get the shifter base unbolted from the torque tube mount then it should come off. There is a small gasket that can keep it from coming off easily, though. Give it a tug or a tap with a mallet :D
Old Apr 3, 2002 | 09:01 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: How do I remove the stock shifter? (C5Cemo)
Hmm, not sure. Maybe your answer is somewhere here. http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Old Apr 3, 2002 | 09:45 PM
Horsepower's Avatar
Horsepower
Default Re: How do I remove the stock shifter? (racer44)
thanks racer that is perfect! :smash:
To How do I remove the stock shifter?
