NO pedal response
Old Nov 5, 2010 | 03:05 PM
ssdungeon's Avatar
ssdungeon
Default NO pedal response
Help.
The story. My HPT usb cable fried when programming so I had my ECM sent off to be reflashed. It came back the car runs fine but the pedal doesnt do anything I have checked all the fuses. Is there any module or something that I may have missed?
I did unplug the star connectors and all the modules i know about, even took the ECM down twice to reseat the connectors. No response still.
Fuse 17 is good. Is there anything else related to what may be causing this. Also when I crank it up the Throttle body cracks as normal so voltage is getting there.
Old Nov 5, 2010 | 03:07 PM
ssdungeon's Avatar
ssdungeon
Thanks in advance
Old Nov 5, 2010 | 03:22 PM
BigGun's Avatar
BigGun
Originally Posted by ssdungeon
Help.
Have you checked the DIC for codes?
http://www.c5forum.com/ayc/dtcdic.php
Old Nov 5, 2010 | 11:25 PM
ssdungeon's Avatar
ssdungeon
Default codes
System Readiness Tests Results
Specifically Monitored Systems Tests Results
Oxygen Sensors Tests Results
Diagnostic Trouble Codes
C1255 "EBCM RAM Error" H ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
C1276 Unassigned H ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
C1278 Unassigned H ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
C1281 Unassigned H ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
C1286 Unassigned HC ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
C1288 Unassigned H ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
U1255 H ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
B2587 "Parklamp Control Circuit Low" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
B2588 "Parklamp Control Circuit High" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
B2592 "Left Cornering Lamp Circuit Low" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1255 H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1096 "Lost Communications With Driver Information and Displays Controller - Device $60" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
U1040 "Lost Communications With Brake/Traction Controller - Device $28" H ($40) "Body Control Module (BCM) or Dash Integration Module (DIM)"
B2282 "Right Rear Seat Assembly Forward Switch Circuit Low" H ($A0) "Driver Door Module (DDM)"
B2284 "Right Rear Seat Assembly Forward Switch Circuit Open" H ($A0) "Driver Door Module (DDM)"
U1064 "Lost Communications With Body Controller - Device $40" H ($A0) "Driver Door Module (DDM)"
U1096 "Lost Communications With Driver Information and Displays Controller - Device $60" H ($A0) "Driver Door Module (DDM)"
B2283 "Right Rear Seat Assembly Forward Switch Circuit High" H ($A1) "Front Passenger Door Module (FPDM)"
B2285 "Right Rear Seat Assembly Rearward Switch Circuit" H ($A1) "Front Passenger Door Module (FPDM)"
U1064 "Lost Communications With Body Controller - Device $40" H ($A1) "Front Passenger Door Module (FPDM)"
U1096 "Lost Communications With Driver Information and Displays Controller - Device $60" H ($A1) "Front Passenger Door Module (FPDM)"
B0851 "Wait/Glow Plugs Indicator Circuit Range/Performance" H ($A6) "Driver Seat Module (DSM)"
B0856 "Battery Voltage Indicator Circuit Range/Performance" H ($A6) "Driver Seat Module (DSM)"
U1064 "Lost Communications With Body Controller - Device $40" H ($A6) "Driver Seat Module (DSM)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($A6) "Driver Seat Module (DSM)"
U1255 H ($B0) "Remote Control Door Lock Receiver (RCDLR) or Remote Function Actuation (RFA)"
U1096 "Lost Communications With Driver Information and Displays Controller - Device $60" H ($B0) "Remote Control Door Lock Receiver (RCDLR) or Remote Function Actuation (RFA)"
U1064 "Lost Communications With Body Controller - Device $40" H ($B0) "Remote Control Door Lock Receiver (RCDLR) or Remote Function Actuation (RFA)"
U1016 "Lost Communications With Engine Controller - Device $10" H ($B0) "Remote Control Door Lock Receiver (RCDLR) or Remote Function Actuation (RFA)"
C2120 Unassigned H ($B0) "Remote Control Door Lock Receiver (RCDLR) or Remote Function Actuation (RFA)"
History data
Old Nov 9, 2010 | 12:29 AM
ssdungeon's Avatar
ssdungeon
No codes I can see tell me anything.
Anyone have any other ideas?
Old Nov 9, 2010 | 01:30 AM
wesz0691's Avatar
wesz0691
maybe TAC module?
Old Nov 9, 2010 | 02:08 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
On many drive by wire cars the throttle will NOT respond IF you have messed with the " ETC TQ. limit reduction table "---many tuners will set this whole table to 100%--this usually eliminates the no throttle---BUT be careful the opposite affect would be the throttle will "hang" WOT for a few seconds after lifting----Then i back off the 100% setting to around 1/2 way to the end----there may be other tables in the same file that affect the throttle as well--they are all found in the "traction control " section
To NO pedal response
