Wheel studs broke
Old Nov 5, 2010 | 08:45 PM
Beeman4266's Avatar
Beeman4266
Default Wheel studs broke
I bought a C5 4 weeks ago (Love it) However, while driving yesterday i turned a corner at about 20 and all of a sudden i heard this bird chirping sound (It could actually be mistaken for a bird) And a really loud knocking. I thought weird, but okay. I was going to have my dad look at it when I got home. I got home and let it sit for a bit, and drove it around the neighborhood, problem still persisted. So my dad looked at it and found the most obvious thing, the wheel studs were sheered off, 3 actually. I'd gotten extremely lucky considering my wheel was held on by 2 bolts, wobbling back and forth.
So I'm going to do some research, but I could use some help figuring out which wheel studs are the best. I also have aftermarket ZR1 rims that came with the car with the person I bought it from.
Old Nov 5, 2010 | 09:14 PM
Jnape's Avatar
Jnape
If your aftermarket rims ARE hubcentric, than the studs were probably overtorqued by a bunch.
Old Nov 5, 2010 | 09:15 PM
Beeman4266's Avatar
Beeman4266
That's what my dad guessed, The guy we bought it from probably didn't have a torque wrench..
Old Nov 6, 2010 | 12:37 AM
Bill Dearborn's Avatar
Bill Dearborn
If all you are doing is just driving around on the street and highway the stock studs do just fine. I have been running track events for 18 years with stock studs and have never had an issue with them that I didn't cause.
It may be a good idea to check all of the wheels to make sure they are fitting on the hubs and studs correctly. Breaking 3 studs at one time sort of indicates the wheel wasn't seated on the hub properly and was probably wobbling around a little before the studs snapped.
Bill
Old Nov 6, 2010 | 12:40 AM
Beeman4266's Avatar
Beeman4266
Bill
We're going to check all the wheels with a proper wrench to assure they're all perfectly fitted. Also, every once and a while when i turned sharp there would be a knocking in the back end, similar to the one that I heard when the tire was falling off. However, it was much for faint and would go away. My dad heard it to, but due to it going away, we never thought anything of it. I guess that was an early sign that something wasn't right with the back tires.
I've heard that ZR1 aftermarket rims have problems with stock wheel studs, but I'm not entirely sure. My dad wants to buy the best possible, considering i could have totaled the car, I was lucky enough for the wheel to hold..
Thanks ~ Alex
Old Nov 6, 2010 | 02:07 AM
MTPZ06's Avatar
MTPZ06
Stockers should be more than adequate when torqued correctly. Otherwise, you can always upgrade to ARP.
Old Nov 6, 2010 | 04:32 PM
rebelheart's Avatar
rebelheart
Perhaps the lugs were loosened before they broke by someone who wanted those wheels!
Old Nov 6, 2010 | 07:06 PM
Solofast's Avatar
Solofast
Rather than being overtorqued, it is far more likely that they weren't properly torqued in the beginning. The noise you heard was the wheel being loose and when your lugs aren't tight you put cyclic loading on the studs which can break them in a hurry.
Inspect the wheel and make sure the hub centering feature on the wheel isn't damaged from wallowing around. Make sure the wheel surface is clean and isn't corroded, and make sure the disk hat is clean of rust and surface crap.
Replace ALL of the studs on that hub. The two remaining studs have seen cyclic loading and are no longer safe and must be replaced. The stock studs are more than adequate.
Do that and you will be fine.
You were very lucky not to have lost the wheel.
Old Nov 6, 2010 | 10:47 PM
Beeman4266's Avatar
Beeman4266
I'm not sure what was the problem, due to the wheels coming with the car. We're going to replace the studs on the back left (the ones that broke) and the back right also, hopefully I won't ever have something happen like this again.
And yes, my dad has told me a few times that I was incredibly lucky the wheel stayed on and I didn't total the car, i'm thankful it held.
Old Nov 6, 2010 | 11:04 PM
sami85L98's Avatar
sami85L98
Iam a mechanic and i see cars with broken and threads chewed due to previous shops over torqued, we always torqued wheel nuts no matter what vehicle, its mandatory in our shop. Well replace with stock stud and you be fine with it.
Old Nov 7, 2010 | 09:46 AM
rebelheart's Avatar
rebelheart
Our techs all use torgue sticks when using an impact and have for many years.
Old Nov 7, 2010 | 12:07 PM
sami85L98's Avatar
sami85L98
Thats what we use too, those sticks work pretty good, very close to torque specs.
Old Nov 9, 2010 | 09:31 AM
rebelheart's Avatar
rebelheart
We also replace the sticks every year as they are used a bunch in the shop.This is to insure that they are in spec.
Old Nov 9, 2010 | 09:46 AM
WELEPRO's Avatar
WELEPRO
Torque sticks work well, we use them in our shops and have for years. Most limit torque to 80 Ft. Lbs, and the remainder is done by hand with a torque wrench. The amount of air pressure supplied to the impact gun can effect how tight the lugs go, even using a torque stick. They're not fool proof.
ZR1 replica wheels should be hub centric. This problem could also be caused by using the wrong size lug nuts, or lugs with the wrong seat. You may want to see what thread pitch lugs are on the car, it's usually stamped on the lug itself.
Our cars use a 12mmX1.5 lug, with an acorn(conical) seat.
The stock wheels studs are fine to replace them with.
To Wheel studs broke
