tires
Old Nov 5, 2010 | 10:34 PM
wphillip's Avatar
wphillip
Default tires
new tire purchase ( goodyear unable to get tire to pop,as they say,they brought tire pressure to 120 pounds still no pop.? is tire still good or should i request a new tire.car stood overnight at goodyear waiting for pop(seal):goodyear eagle 1 emt rulflats
Old Nov 5, 2010 | 11:02 PM
cruisemon's Avatar
cruisemon
If by "pop" you mean having the bead seal on the rim - dude if they put 120 psi on that puppy and the seal didn't move, ask for another tire. Anyone know what pressure has to be for the tire to REALLY pop, as in rupture the carcass?
Charlie
Old Nov 6, 2010 | 09:00 AM
wphillip's Avatar
wphillip
Default tires
Charlie
thanks (overnight and still did not seal) requested another tire everything is good
Old Nov 6, 2010 | 04:29 PM
rebelheart's Avatar
rebelheart
Did they use a proper lubricant on the bead when they mounted the tire?
Old Nov 6, 2010 | 05:42 PM
cruisemon's Avatar
cruisemon
Been wracking my brain about why the tire wouldn't seat. The ONLY answer I came up with is they were trying to put a front (17") tire on a rear (18") rim. The 17" can be stretched enough to get over the edge of the 18" rim because the tire is being stretched into an ellipse (which it will accommodate) but won't seat on the rim because the bead won't stretch radially enough to get the 17" tire up the lip of the 18" rim. It might be interesting to ask them. On the other hand, you may not WANT to know if a tire dealer has people that careless (if that is what happened).
Charlie
Old Nov 6, 2010 | 08:57 PM
wphillip's Avatar
wphillip
Charlie
19inch rims,right tire for rim (think tire was a bad one,just would not seal
Old Nov 6, 2010 | 10:39 PM
onebighitter's Avatar
onebighitter
All tires do not pop when sealing. If tire is not sealing or seating the tire mounting technician needs to work harder in getting tire to seat. The technicians at my work know tricks to get tires to seat. I have seen some tires to be a real pain, it seems they are mine though.
To tires
