The passenger door lock unlocks as it should with the remote, the buttons and the ignition shut off but it does not lock electronically at all.
I used a test light on the harness connector and the tan wire lights when I push the unlock button but the grey wire does not when I push the lock button.
Does this indicate a bad passenger door control module and if so, any idea how much I might be able to ge tone for?
Yea these modules have relays that go south pretty often. There is a lock relay and unlock relay on each one. There is a thread in the stickies by pewter99 that may help you. For some reason the pictures are gone now but maybe pewter99 still has them and can send them to you. Good Luck.
Link in post 20 of DIY is not working. PM'ed pewter99 for help.
cc
I found post 32 and that should help.
Reason: update
yeah that member is no longer with us so I had to pull the link as the pics were not working
