Alignment issue?
Old Nov 8, 2010 | 08:43 PM
STROK3D's Avatar
STROK3D
Default Alignment issue?
So I changed my oil this past weekend and noticed that the inside of the driver's side front tire is VERY worn. The car has a stock suspension but is lowered with stock bolts & cut bushings in the front and longer bolts in the rear. After I lowered it about a year and a half ago, I had an alignment done on the car. Is this an alignment issue? Or does it sound like I need to replace the shocks?
Old Nov 8, 2010 | 09:07 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I would definitely have the alignment checked. It is not uncommon for the cam bolts to slip if not properly torqued. Also it's a good time to thoroughly check the rest of the suspension components.
I would doubt that a work shock would cause the wear.
Old Nov 8, 2010 | 10:13 PM
jrose7004's Avatar
jrose7004
Sounds like an alignment problem to me.
Old Nov 9, 2010 | 08:50 AM
rebelheart's Avatar
rebelheart
To much negative camber,for whatever reason.
Old Nov 9, 2010 | 08:57 AM
SaberD's Avatar
SaberD
did you drive it around for a few hundred miles after you lowered it before you got the alignment?
Old Nov 9, 2010 | 04:49 PM
STROK3D's Avatar
STROK3D
Yes, it was at least a couple of hundred miles before the alignment was done. I'm making an appointment to get an alignment done. I'll post up what the alignment shop says about the current settings.
Old Nov 9, 2010 | 05:37 PM
wcsinx's Avatar
wcsinx
Could also be that the Z06 alignment specs are simply too aggressive for how you drive. I've seen several people here mention that they got inner wear (indicating too much -camber) with the Z06 alignment #'s and going to the base #s was the solution.
Old Nov 9, 2010 | 07:29 PM
STROK3D's Avatar
STROK3D
But only extreme wear on one side of the car? And by extreme, I mean EXTREME, compared to the wear on the rest of the tire.
Old Nov 9, 2010 | 08:05 PM
wcsinx's Avatar
wcsinx
oh yikes ... missed that part
Yeah, something has come loose.
Old Nov 11, 2010 | 02:33 PM
STROK3D's Avatar
STROK3D
Camber on the front left was -1.5* before the alignment, so it was an alignment issue. And yeah, it wore the tires enough that they need to be replaced. Awesome.
Thanks for the input, everyone.
To Alignment issue?
