Snow Methanol Injection
Old Nov 9, 2010 | 08:36 AM
curtbriggs's Avatar
curtbriggs
Default Snow Methanol Injection
I just finished installing an A&A Vortec T trim and I'm installing a Snow Methanol system. I'm trying to find a place in the engine compartment to mount the Snow Variable Controller. The only place that looks likely is to pop rivet a bracket to the plenum chamber outer wall, next to the battery, leaving room to service the AC system. I'd have to tig up an aluminum bracket and thought I'd also mount the optional solenoid on the bracket next to the controller.
Anyone find a better place or come up with a more trick mounting system?? Where did you mount the system methanol low level light? I have the 2.5 gal. reservoir and I'm going to mount that in the luggage compartment in the center well along with the pump. Looks like I might have to cut out a hole in the well cover for the filler cap if I cant get it low enough by removing the carpet and the layer of sound proofing I installed.
Cheers, Curt
