OMG dam bolt
Old Nov 10, 2010 | 09:04 PM
tramminc's Avatar
tramminc
Default OMG dam bolt
I broke (over tighened) one of the long bolts on the oil pan near the tranny, all the other are tight. will this thing leak?
Old Nov 10, 2010 | 09:06 PM
tramminc's Avatar
tramminc
spec's said 13 ft lbs
Rr Exhaust Hanger Mounting Bolts 50 N·m 37 lb ft Knock Sensors 20 15 --
Rr Shock Absorber Lower Mounting Bolt 220 N·m 162 lb ft Oil Filter 30 22 --
Rr Susp Xmember Mounting Nuts 110 N·m 81 lb ft Oil Filter Fitting 55 40 --
Shift Control Mounting Bolts 30 N·m 22 lb ft Oil Level Indicator Tube Bolt 16 12 --
Shift Control Closeout Boot Retaining Nuts 12 N·m 106 lb in Oil Level Sensor 13 -- 115
Transaxle Mount Bracket to Differential Bolts 50 N·m 37 lb ft Oil Pan Baffle Bolts 12 -- 106
Transaxle Mount to Rr Susp Xmember Nuts 50 N·m 37 lb ft Oil Pan Cover Bolt (Left Side) 12 -- 106
trans to Driveline sup Assm Bolts/Studs 50 N·m 37 lb ft Oil Pan Cover Bolt (Rt Side) 12 -- 106
trans Oil Cooler Rr Pipe Fr Fittings to Junction Fittings at E2n7g Nin·em Flyw20h elbe lf tHsngOil Pan Cover Bolts 12 -- 106
trans Oil Cooler Rr Pipe Rr Fittings to trans Fittings 40 N·m 30 lb ft Oil Pan Drain Plug 25 18 --
trans Oil Cooler Rr Pipe Fr and Rr Retaining Clamp Bolts 12 N·m 106 lb in Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil 2P5an-to-Fr1 C8over) --
trans Shift Control Cable Bracket Retaining Nuts 20 N·m 15 lb ft Oil Pan M6 Bolts (Oil Pan-to-Rr Cover) 12 -- 106
trans Shift Rod Clamp Bolt 30 N·m 22 lb ft Oil Pressure Sensor 20 15 --
trans Wiring Harness to LH trans Case Retaining Bolt 2.5 N·m 22 lb in Oil Pump-to-Engine Block Bolts 25 18 --
Rr Drive Shaft Spindle Nut 160 N·m 118 lb ft Oil Pump Cover Bolts 12 -- 106
Diff Oil Pump Relief Valve Plug 12 -- 106
Differential Case Bolts 55 N·m 41 lb ft Oil Pump Screen Nuts 25 18 --
D
Old Nov 10, 2010 | 09:11 PM
lucky131969's Avatar
lucky131969
I'm confused. You have a Z06, right? So there is no pan on the tranny, or near the trans for that matter. What bolt, at what location, and what did you torque it to?
Old Nov 10, 2010 | 09:12 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
yes
Old Nov 10, 2010 | 09:14 PM
tramminc's Avatar
tramminc
Installing a C5R 427 in a muscle car
Old Nov 10, 2010 | 09:17 PM
lucky131969
.........I flunked out of dental school.
Good luck...
Old Nov 10, 2010 | 09:22 PM
imavettegirl's Avatar
imavettegirl
the more info you give, then better help is given.
Old Nov 10, 2010 | 09:33 PM
tramminc's Avatar
tramminc
Sorry, I had to walk away and kick my own ***
Always listen to that voice in the back of your head telling you to stop.
I was going to put the engine in the car (1968 pontiac catalina) tonight, along with a level 6 tranny so I can begin on the 3.73 gears.
I'm hopeing the auto parts store will have a f body oil pan bolt, the long 1 nearest to the tranny.
Old Nov 10, 2010 | 11:50 PM
robsc501's Avatar
robsc501
Hi There,
So center punch it & drill a starter hole & use a quality easy out & remove it.
robsc501
Old Nov 11, 2010 | 10:22 AM
tramminc's Avatar
tramminc
Originally Posted by robsc501
Hi There,
robsc501
Thanks, i've done that, now I have to find a long bolt today.
Old Nov 11, 2010 | 11:09 AM
corvettebob1's Avatar
corvettebob1
Since when is a 68 Pontiac Catalina a Muscle car?
Old Nov 11, 2010 | 01:42 PM
crainholio's Avatar
crainholio
While your advice is appreciated, you might consider that voice to be saying...
"Buy a decent torque wrench, you're working w/ aluminum parts now."
Broken bolts are only the beginning if you're going to guess on tightening. Warped oil pan, stripped threads, etc.
Old Nov 11, 2010 | 01:47 PM
zeevette's Avatar
zeevette
Kinda what I was thinking. Such a fine motor, and it's not even a Bonneville?
Old Nov 11, 2010 | 10:38 PM
tramminc's Avatar
tramminc
Ahh come on This thing will be bad *** and out run a few vette
Old Nov 14, 2010 | 09:23 PM
MN-Brent's Avatar
MN-Brent
If you dont use torque wrenches, you'll be suckin' hind titty from here to eternity, especially now with the aluminum everything that is LSx.
PS I put an LS1-4L60E combo into my old 82 Corvette and it was the best thing I could have done for that car, loss of weight, easy HP increase, and GM OEM fuel injection drive-ability.
To OMG dam bolt
