Maybe someone can help me with this. I have a '99 C5 with 120k. The rear running lights that come on with the headlights are out. Also the console lights are out. The brake lights do work. I'm thinking it may be the headlight multiswitch. This part is $250.00 Has anyone run into this problem that could help me out Thanks
Do your front corner parking lights work? If so you may want to check the fuses before anything else. Not quite sure if the back corner lights work off the same circuit as the console lights but hey it's worth a shot to troubleshoot the simple stuff first. Good Luck bro.
When my reverse light switch in the tranny failed, it took out the fuse for the auto dimming mirror and some other things. Check all the fuses under the hood and in the passenger footwell before buying anything.
Had the exact same issues and that was the problem. Look around a bit, some forum vendors will be cheaper for the part.
