Dash/instrument lights....
Old Nov 13, 2010 | 06:11 PM
agood1's Avatar
agood1
Default Dash/instrument lights....
Has any every replaced the ballast for the dash lights? It appears the light are fluorescent or some thing similar that takes a high voltage power supply. Mine keep flashing on and off.....I don't think it is the multi-switch as the tail lights are not having any issues.
Just curious if there is a fix for the ballast or if it can be purchased separate from the whole cluster.
Old Nov 14, 2010 | 04:36 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I assume you checked for a loose connection?
You'll probablt have to buy a used cluster and R&R the power supply for the UV tubes. It's the large silver box on the back of the IPC.
Old Nov 14, 2010 | 08:41 AM
agood1's Avatar
agood1
Yes, I checked everything. I has to be the power supply. I have already removed it and opened it up, hoping to find a loose connection or bad solder joint, but so far...nothing. I was hoping to find just the power supply somewhere. It has Toshiba markings on it....
Old Nov 14, 2010 | 07:20 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
They don't sell the background illumination systems by themselves, only the entire IP Cluster as an assembly. Now you could go a recycler and buy it from them.
To Dash/instrument lights....
