C5 Climate Control
Old Nov 14, 2010 | 05:52 PM
trimjc's Avatar
trimjc
6th Gear
Default C5 Climate Control
Drivers side climate control **** stopped working. Temperature is stuck on 73. Turning the **** up or down does not change the temperature. Also have a check engine light on.
1998 with 4,800 miles. Any way to reset?
Thank you for any feedback
Jerry
Old Nov 14, 2010 | 10:53 PM
Carcass's Avatar
Carcass
My 98 stuck on 73,and didn't want to turn on or off most of the time,lived with it for about 6 months,then bought a used 2001 control from Corvette Recyclers for $200,about 5 months ago,and all is good every since.
Pull the codes on the DIC,that should tell you why the Check engine light is on,doubt if it's related to the A/C problem-mine never threw a code when the controller went south...
