LS6 intake bolt TQ and sequence
Thanks in advance!
The first pass, tighten to 44 INCH-lbs, then, on the 2nd pass torque them to 89 INCH-lbs. NOTE: These are inch pounds, NOT foot pounds!.
Also, be SURE the threads (and those in the heads) are clean and not still clogged with old thread sealer/dirt/corrosion. Use a small amout of anti-seize compound on the threads too.
I use this converter to convert inch pounds into foot pounds and 44 inch pounds came out to 3.6 foot pounds For the first pass.
I use this converter to convert inch pounds into foot pounds and 89 inch pounds came out to 7.4 foot pounds For the Second pass.
