Phantom Current Draw - No Joy
Old Nov 15, 2010 | 03:26 PM
krawfo's Avatar
krawfo
Default Phantom Current Draw - No Joy
I've read many of the threads on phantom current draw. I'm showing 5.74 amps with everything off. My battery will run dead in 10-12 days if I don't start it. Grounds all look good. I pulled each fuse individually with no change in current draw.
Any suggestions would be greatly appreciated.
Old Nov 15, 2010 | 03:49 PM
dougbfresh's Avatar
dougbfresh
5.7 AMPS??? That should be EASY to track down, with 5+ amps, there should be at least a warm wire somewhere. A clamp on ampmeter might help track it down. Are you sure of that current draw? Check at night too in a dark garage, see if you see a light on somewhere (like the sunvisor lights or under the hood) that you normally would not notice.
Old Nov 15, 2010 | 04:30 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
With that high a current draw get yourself an AMP CLAMP METER (FLUKE is a good brand). Start testing various wires for that high a current.
Toque
Old Nov 15, 2010 | 05:43 PM
krawfo's Avatar
krawfo
Thanks for the replies and suggestions. Can someone point me towards a thread on how to check out the alternator diodes and the location of the headlight control module?
Thanks again.
Ken
Old Nov 15, 2010 | 07:21 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If you pulled all of the fuses and you're still getting a large draw like that, you need to look at items that are not turned off or on by the ignition.
(i.e. Seats, Door Controls, BCM, PCM, Cigarette Lighter, Headlights, Brake Switch, Hazard Switch, etc ...)
Old Nov 15, 2010 | 07:31 PM
samarai's Avatar
samarai
5.7 amps.... that ain't chump change... you have something shorted probably in the cab somewhere... agree feel the wires to find one that is warm.
Old Nov 15, 2010 | 07:52 PM
CTD's Avatar
CTD
Your battery won't last 10 to 12 days @ 5.74 amps draw. So I'm guessing something is not right with how you are trouble shooting.
Old Nov 15, 2010 | 08:25 PM
ZeeOSix's Avatar
ZeeOSix
+1 ... that was my thoughts also.
krawfo - are you waiting at least 20 minutes to make sure all the computers have gone into "sleep mode" before checking the parasitic current draw? If not, you will see way more current draw then what is normal.
After all the computers have gone into sleep mode, then the current draw should drop down to ~ 20 mA.
To Phantom Current Draw - No Joy
