what is behind the engine?
Old Nov 19, 2010 | 01:16 PM
vaportech's Avatar
vaportech
Default what is behind the engine?
I dropped a oil sending unit in that dark hole behind the engine and I heard it fall a few inches. How do I get to it? Do I need to jack the car up and take off the torque tube cover plate? Please help! Thanks!
Old Nov 19, 2010 | 02:28 PM
Last C5's Avatar
Last C5
Just the clutch bell housing and then the torque tube. More than likely it got hung up on the wiring harness that runs down the top of the torque tube and Ys on top the bell housing just in back of the engine. Magnetic probe??
Old Nov 19, 2010 | 03:20 PM
vaportech's Avatar
vaportech
It is a brass sending unit
Old Nov 19, 2010 | 03:28 PM
imavettegirl's Avatar
imavettegirl
gripper tool.
usually 1 feet long or so and has a plunger and grippers on the ends.
Old Nov 19, 2010 | 03:34 PM
vaportech's Avatar
vaportech
Originally Posted by imavettegirl
gripper tool.
That would work great if I could see it!
Old Nov 21, 2010 | 09:50 AM
rebelheart's Avatar
rebelheart
You are gonna have to jack it up and do a lighted search!
Old Nov 21, 2010 | 12:33 PM
wwwFLA's Avatar
wwwFLA
Originally Posted by vaportech
What is behind the Engine?
A little vacuum hose that controls my HVAC that I can't get to without removing the intake!
Old Nov 21, 2010 | 01:02 PM
lucky131969's Avatar
lucky131969
I'm on pins and needles........waiting to see how this turns out.
Old Nov 21, 2010 | 01:29 PM
Dope's Avatar
Dope
Resident moron
I'm pretty sure there is a small black hole back there. Sorry
Dope
Old Nov 21, 2010 | 03:12 PM
vaportech's Avatar
vaportech
You might be able to get the that from the underside of the car. Don't quote me on that but there seemed to be a lot more room from the underside to get up there. You may have to borrow a female to contort a smaller arm through there but I think it is a lot more possible to replug that hose from underneath. If not, pull the intake...I just had to do it twice because NAPA sold me a faulty sending unit! And if you do mess something up or forget to plug something back in, its not going to be catastrophic just let the engine idle for a good 10 minutes and check your codes.
Goodluck!
Btw...put an extension on that tiny vacuum line. I used guage pressure line and took the copper out of a 10 guage piece of wire to use the insulation as the connector.
Old Nov 29, 2010 | 09:46 AM
wwwFLA's Avatar
wwwFLA
Thank you, I'll try looking underneath when I get it on a lift.
To what is behind the engine?
