I tried to do the relearn process for the PCM and then went for a 40 mile drive. All was fine - no codes. So I drove onto the expressway and floored the accelerator pedal, at about 5000 rpm it happened again. Reduced engine power, service active handleing and the three codes came back.
Will the PCM learn it's way out of this, or should I just get it re-tuned?
I imagine it's lean because of the increased airflow from the 90/90. And for some reason it's triggering the TCS issue.
Are there any other tricks I can do to get it to work properly?
My first thought was an air leak somewhere. But I get both the Bank 1 and Bank 2 lean codes, so it seems to me perhaps it's just the increased airflow? Maybe the gaskets on both the right and left side didn't seat properly? I find it hard to believe that both sides are screwed up - though they certainly could be...
Someone here on the forum had a WizBang Gizmo that connected to the front of your throttle body and could be pressurized, this way you could detect for leaks in that system. I'm not totally sure how it all worked, but seemed cool.
Adding a FAST 90 and 90mm TB is a pretty major change. I would have it retuned. You may be seeing an issue from the larger TB and stock tune if in fact it is stock.
It is not currently on the stock tune. I am planning to get it re-tuned.
I was just wondering if the computer would do any adjustments. I was under the impression that it will do some minor adjustments and was looking to see if others had similiar codes that I have.
Pete,
Get it back to Doug at ECS ASAP. That 1278 code haunted me for a while after my engine swap and actually after the initial power tuning done by a real pro on a Dynojet. It's definitely caused by the increased airflow of the 90/90 set-up. There are some settings that need to be changed in the MAF tables and it will go away and not come back. I'll bet good money that Doug knows exactly what it is and what to do to correct it!
I'm still woriking on it.
The search continues...
Well my first thought, along with some of your suggestions...
I'm not sure why I didnt just put new gaskets on when I did the initial install...
New manifold and TB gaskets - lean problem solved.
Took it out for a spirited drive and thought all was well with my ride. Then after several max effort accelerations it went into limp mode - 0068 and 1278...
I changed out the TPS and have not had a chance to drive it yet - perhaps this will fix it?
Regardless, I have talked to Doug, and if I cant get it, he'll fix it up right...
