How do you warm up Nitto drag radials?
Old Apr 5, 2002 | 10:44 AM
need4speed170's Avatar
need4speed170
Default How do you warm up Nitto drag radials?
How do you warm them up in a 6speed. Do you just dump it and shift to second? Is there a proper way to get them hot?
Old Apr 5, 2002 | 10:52 AM
Austrian Vette's Avatar
Austrian Vette
Default Re: How do you warm up Nitto drag radials? (need4speed170)
On my MN6 I went around the water and then pushed the throttle and shifted to second. I needed to get them melting to get best traction.
Line lock would help a lot!!!!
It´s easier now with the A4 :D
Hope that helped.
Michael
Old Apr 5, 2002 | 11:06 AM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: How do you warm up Nitto drag radials? (Austrian Vette)
5 second smoky burnout :cool: :yesnod:
hope that helps
Old Apr 5, 2002 | 11:53 AM
NassyVette's Avatar
NassyVette
Default Re: How do you warm up Nitto drag radials? (Ram Air Tony)
Go around the box, back in, spin them quickly for a second to coat them in water, pull out infront of the water, rev to 5k and dump the clutch, as the tires start roasting apply the brake QUICKLY about 3/4 of the way down to stop it from moving forward, hold it for about 8 seconds, release the brake, pull up to the line and launch around 3,500. You might wanna find a clear street late at night to practice mashing the brake down without the car bogging, you'll get it within a few tries. Also, traction control OFF!
Have fun.
Adam :seeya
To How do you warm up Nitto drag radials?
