check eng lite
Old Nov 21, 2010 | 10:24 AM
jims01vette's Avatar
jims01vette
Default check eng lite
eng lite came on on my o1 vette, had it checked at local parts store. probable cause showed 3. air pump electrical circuit fault, blocked air system, failed air pump. vette has 31.000 miles. the code was p1416.
Old Nov 21, 2010 | 10:33 AM
feeder82's Avatar
feeder82
read this thread
http://forums.corvetteforum.com/c5-t...eck-valve.html
Old Nov 21, 2010 | 02:37 PM
jims01vette
ok i did it again and recieved this 10pcm 1code
Old Nov 21, 2010 | 02:57 PM
lucky131969's Avatar
lucky131969
The procedure that was provided to you, explains how to extract the individual codes, as what you posted tells us nothing. Take time to read the procedure completely. You already know you have a P1416, but knowing how to look up the codes will help you in the future. Also, you have been provided a link with info about the P1416 code. People are trying to help you, but you have to read what is given.
Old Nov 22, 2010 | 07:07 AM
99 vett babycar's Avatar
99 vett babycar
we need to know THE NUMBER of each code AND if the number has
an H or HC after it.
Old Nov 22, 2010 | 07:23 AM
jims01vette
ok, thanks 99vett.
Old Nov 22, 2010 | 08:12 AM
jims01vette
ok, thanks 99vett.
ok got the codes. 1287, 1288, 2252, 2282, 2283, 2284, 2285, u1064. thanks for the help guys. all the codes are H
Old Nov 22, 2010 | 09:57 AM
jims01vette
Originally Posted by 8VETTE7
Close but there is a prefix alpha character in front of each code.
ie the letter B or the letter C or the letter P etc.
So a B1287 H is different than a P1287 HC etc, etc
yea i went back and looked at that again. it has been a learning process, thanks again. do you know of a good repair manual?
Old Nov 22, 2010 | 10:01 AM
jims01vette
8vette, i had a code c1287h, c1288h, b2252h, u1064h this one shows loss of comm with bcm?
Old Nov 22, 2010 | 10:34 AM
jims01vette
ok, i will check again. thanks
Old Nov 22, 2010 | 10:49 AM
Fast Cop's Avatar
Fast Cop
If all your codes had a H at the end and none of them had a C then just clear them all and drive. Several things can cause a code to pop up and just show as a history (low voltage on battery being the most common).
Old Nov 22, 2010 | 10:55 AM
jims01vette
ok, i think i got it right. 28 tcs 2 codes- c1287h, c1288h. Ao ldcm 4 codes- b2252h, b2282h, b2284h, u1064h. A1 rdcm 3 codes- b2283h, b2285h, u1064h.
Old Nov 22, 2010 | 11:01 AM
jims01vette
ok, thanks cop.
Old Nov 22, 2010 | 11:11 AM
jims01vette
ok, thanks again you been a great help.
To check eng lite
