Hey folks. I just installed the blackwing on my 01 coupe 6 speed but havent driven it much yet. I am waiting for the hurst shifter to arrive. What are the recommendations for the next $500 in performance parts? I will never race the car on a track and I am not really concerned about my top end speed. But I do love to wind thru the gears and enjoy a red light test now and then. Your experienced is always appreciated.
About the install? Were you able to get the top plastic "tunnel" seated properly on the grommet holes? I loosened everything and still can't get it to seat right. That "tunnel" is about an inch above the grommet pins.. :(
we only have a few Stingers left,to the best of my knowledge we are the only discounter with any in stock.Call Nate at XTREME 480-517-4969 the price is only 450.00 DELIVERED and any muffler shop can install it 30 minutes.It will give you a small HP gain 7-10 ponnies 5 over a 900.00 bassani which is great system.Good Luck David Smilovic.
You might want to check to make sure you have fully seated the rubber connector between the airbridge and the MAF connection point.. and at the airbridge and blackwing.. this might help. I had to spend some time pushing and wiggling-with connection clamps loose before it seated properly Keep trying,you'll get it! :D
If you haven't considered the vortex coupler , itwouldn't hurt and then maybe a hi-performance MAF or translator..then the exhaust. Go with the Long tube headers/x-pipe and a set of good exhausts( Corsa's,B&B,Bassani etc.)
I always believed in an efficient Intake /Exhaust for low cost h.p./tq. gains:D
