"Lowering the C5"
Old Nov 26, 2010 | 12:37 AM
Darkness1988's Avatar
Darkness1988
Default "Lowering the C5"
https://www.corvetteforum.com/c5/sus...owering-c5.php
is the link the "Lowering the C5" page. its on the Home page for C5 users before you enter the forums. Is this legit? has anyone tried it? How much does it lower your car? (seems too easy)
-thanks
Old Nov 26, 2010 | 08:05 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Doing the front, there's one, possibly two, important steps left out of that procedure. The first is that you need to take the tension off the spring, in order to be able to turn the adjusting screw. You do that by placing a small piece of wood under the far end of the spring, and use a jack to raise the spring 1/8" or so. You need to be extremely careful not to scratch, dig, or gouge the spring.
Secondly, especially since the newest C-5s are now 5-6 years old, the adjusting screws may be pretty well stuck in the threaded inserts, and aren't likely to readily turn. The threaded inserts are molded into the spring, but too much force in trying to turn the adjusting screw, will break the insert loose, and you'll then be adjusting the ride height of your car with its BRAND NEW spring....(about $400)
There's quite a bit of height adjustability in the rear WITHOUT having to cut the bushings, and/or installing longer bolts. In fact, you shouldn't cut the bushings...if you can't go low enough by turning out the stock bolts, replace them with longer bolts.
Finally, I doubt that I've seen any two C-5s sitting at the same ride height...they're all over the place. Therefore, if you tell people you want to drop it an inch, three-quarters of an inch, etc, it doesn't mean all that much, because everybody's starting at a different point.
FWIW, I dropped my car just short of an inch, by using all the adjustment in front, and the stock bolts in the rear. I did, however, replace the rear bushings with polyurethane pieces, and the OE hex nut with a "ny-lock" nut. My car is F-45 equipped, so I couldn't "slam" it, but since I still need to get in and out of driveways, I'm content with its stance.
Old Nov 27, 2010 | 10:42 AM
Triple Black 04's Avatar
Triple Black 04
Cruising
I installed Ebach lowering kit on my 04 , front is fine but rear is too low. Should nuts on bolts be tightened or loosened to raise back up ? Ride is very choppy on alot of Texas roads but very nice on smooth highway.
Old Nov 27, 2010 | 11:10 AM
Dennis Wilson's Avatar
Dennis Wilson
Tightened.
Old Nov 27, 2010 | 11:38 AM
Triple Black 04
Cruising
Thanks Dennis , I think I should have tried lowering on stock bolts first , longer ones nut is bottomed out and VERY low. Looks great but lost alot of comfort. Also went with Bilstein Sport shocks !
Old Nov 28, 2010 | 09:04 AM
leadfoot4's Avatar
leadfoot4
Put your stock bolts back in the rear, and just get a pair of "ny-lock" nuts, so you hold adjustment. One other tip....make sure that the car is level, side-to-side. Don't measure at the fenders, however. Measure from the center of the inner a-arm pivot bolts to the ground. Equalize that dimension side-to-side, and in order to keep the car "aero stable", the front needs to be a tad lower than the rear. This keep air flow going over, and pressing down on the hood, rather than going under the car, and making it "floaty".
Old Nov 28, 2010 | 06:02 PM
Triple Black 04
Cruising
Thanks for info Leadfoot, I need to get new Grade 8 bolts, a friend did swap and doesnt have stock ones anymore. Do you know length of stock ?
To "Lowering the C5"
