DIY header installers...
Old Nov 30, 2010 | 11:38 AM
bucketlist1957's Avatar
bucketlist1957
Default header install
I wrote a set of instructions for installing a set of ARH long tubes. They are located on the last page of the DIY at the top of the Tech Forum. It may not be the best but I did the best I could. Hopefully it would be helpful to you. If you can get your car above 20 inches. off the ground you should be fine.
bumble-z's Avatar
bumble-z
Originally Posted by Kamauxx
Quick question. Does the alternator have to be removed to install headers from the bottom or is that just for top installations?
Pull it. It doesn't take that long & the more room to get your hands up in that area the better.
