Need Some Help w/ Clutch Hydraulics
I've marked the measurements I've taken on the picture below (stolen from the interwebz, not my picture - torque tube is not in place):
The dimensions are taken from the machined surface of the slave, where the spring sits, to the bottom of the plastic base of the TOB. Could someone back me up in saying that the slave still has at least .340" of travel in order to properly disengage my twin disc (.340" straight from clutch manufacturer). Based on my old slave, there is plenty of travel.
Warning: If you agree with me, I will have nothing good to say about GM's clutch system hydraulics ever again and will order a TICK tomorrow morning.
Once my wife gets back into town or I can grab some neighborly help, I plan to measure the actual distance the S/C travels during clutch pedal activation. I'll report back when I do.
TIA
They should know the proper travel of the slave.
Anytime you replace the stock clutch with an aftermarket one, you should install an adjustable master. It is just very unlikely that the tolerances of aftermarket will match that of OEM.
good luck with your project.
When you measure the slave distance also check to see if you can tell that both disks are disengaging or whether the floater plate is closer to one than the other. I'm willing to pitch in this weekend too. I feel partially responsible.
With you me and Jerry we could yank the drivetrain, shim the slave and re-stab it in less than a six pack.
