LS1 edit questions
How hard is it to use? Is the software user friendly enough that I don't have to be a GM mechanic to understand it?
Currently using the powerloader program and now want to change gears and torque converter, can I just "tweak" the TTS program to compensate for the gear change? Very scared about sending my powerloader back for reprogramming and never seeing it again.
$550 is a big pill to swallow especially after spending the money on the powerloader, but if the software is easy to use and understand, it may worth it.
Any other comments from those who are using this, please chime in.
Of course, I'm an LS1-Edit fan - "Power to the People!" :smash: :smash: :smash:
David
The stock tables are in the flash I downloaded from the PCM.
Yes, I just toggled that code off. May have also changed it's MIL status too. Again, this is only a temporary workaround until we get hold of 1.05 and can relax the diagnostic parameters to allow more slip without test failure.
BTW, I think A4 tuning is a great place to start with LS1-Edit tuning. There's a limited number of things to focus on and changes can be pretty easily felt.
:cheers:
[Modified by ToplessTexan, 11:48 PM 4/5/2002]
I'm very interested in LS1 edit. While I'm no rocket scientist, like you guys, I'm commited to learning how to tune my LS1 and use the tools now available.
I take it from the discussion that this only applies to A4 cars?
This is also where I'm a little confused about "the tools" LS1 edit is to change the program that previously had to be sent off to be done. But there is also "reprogrammer's like Hypertech and Autotap, which I understand is needed also.
What is the difference? and do these apply more to A4 cars than MN6's
You CAN NOT program tire hight and gears with LS 1 edit, yet!!
That´s the point.
I know it will be able to do it with the next version, but NOT YET!!
That`s why I asked if I can use the HPP3 settings for gears and tirehight until LS1 edit can do it.
Michael
Bill
[Modified by K&B Motorsports, 7:59 AM 4/6/2002]
Bill
Carputing told me tire and gear scaleing doesn´t work yet (version 1.04).
It should come with Version 1.05.
But as TT said it is possible to program for it in an other way.
Now if that works, then I´m happy!! :cheers:
Michael
[Modified by Austrian Vette, 4:33 PM 4/6/2002]
I've used every version from 0.93 through my latest which I got last night 1.05b (which has some really new cool stuff we'll be trying at the track today)
Bill
Bill
Bill, thanks for the info :cheers:
Good to hear!!
Michael
The very early versions of the software (beta) went back and forth a couple of times on in or out with the gear/tire stuff, but since about 0.98 it's been there.
Bill
Bill
With respect to the question of utilizing the HPP3 for some of this, yes you can do this. What you cannot do is merge subets of the flash at the time of program (i.e. part from the HPP3, part from a MicroTuner, part from... ) Just adjust your HPP3 flash as necessary, read it from the PCM w/ LS1-Edit's programmer and save that file, and recover the HPP3 programming from the PCM to the HPP3 unit. You can now make additional changes as necessary to the file you created and flash to your PCM.
