got a few questions, need some help?????
1i have a problem with my lights dimming every time my sound system hits is there anything i can do to fix it??
2what kind of gears should i put,i have a automatic and its my every day driver so im looking for a good street set up any thoughts??
3 what is the purpose of a underdrive pulley? and should i get one??
4 should i change the lifters when i do the heads??
5 are steel retainers good or do i have to get titanium??
6 is a new chain good or do i have to get a double chain set up??
7 and finally what else should i do to the car for more power??
THANK YOU!!!
1i have a problem with my lights dimming every time my sound system hits is there anything i can do to fix it?? Check your grounds.
2what kind of gears should i put,i have a automatic and its my every day driver so im looking for a good street set up any thoughts?? 3.42 seems to be really popular with the A4 crowd
3 what is the purpose of a underdrive pulley? and should i get one?? It drivers the accessories slower, thereby allowing the engine to make more HP. If you're having troubles with the lights dimming when the stereo is loud - I would advise against it.
4 should i change the lifters when i do the heads?? Not really necessary - unless you plan to track your car a lot
5 are steel retainers good or do i have to get titanium?? Titanium are lighter and stronger. They usually come with a spring kit. You will want a new spring kit with the heads
6 is a new chain good or do i have to get a double chain set up?? just for pease of mind. You will have the whole thing apart - now is the time to do it.
7 and finally what else should i do to the car for more power?? what ever your budget allows.
THANK YOU!!!
Best of success with your project.
1i have a problem with my lights dimming every time my sound system hits is there anything i can do to fix it?? If you're talking about the bass hitting then you will need a capacitor to store energy for the hard hitting lows
2what kind of gears should i put,i have a automatic and its my every day driver so im looking for a good street set up any thoughts?? I agree with the 3.42 idea
3 what is the purpose of a underdrive pulley? and should i get one?? Same principle as changing the rear end gears; takes less power to spin the accessories.
4 should i change the lifters when i do the heads?? No need. But there are some nifty options should you choose to. The lifter for the CTS-V racing whatever engine are good to 8,500 rpm (if you plan on getting that crazy) Also, you could get a set of Comp Cams lifters that help against "pump-up" and subsequent valve float. Again, no real need at this point.
5 are steel retainers good or do i have to get titanium?? less weight is always good, but your set-up doesn't really require titanium. If you have the money, do it, if not, don't. If you're not using the light weight LS6 valves, then not a lot of sense using titanium goodies. If you're using the LS6 valves then compliment them with the light weight goodies. note: not all 243 heads have the light weight valves
6 is a new chain good or do i have to get a double chain set up?? OEM chain is strong, just replace with new while in there. Upgrade if you want though, can't hurt.
7 and finally what else should i do to the car for more power?? Comp Cams LSr camshaft (I'm a fan of Comp Cams, lol ). Have the heads port and polished and blend the short-side radius.
Think about another cam. Your car should work well with a 224-228@ 113-4, and about .580lift. Way better than a GM hot cam, IMO. Of course, good springs, and get the Ti retainers.
The car is an 03 A4 Coupe, 3:42 gears and all of the "bolt-on mods". I ended up with 416 rwhp and 392 rwtq, a sweet sounding lope. Car runs like the proverbial "raped ape".
