59cc heads...
Old Nov 30, 2010 | 10:05 AM
BoostRetard's Avatar
BoostRetard
Default 59cc heads...
Looking at a set of ported 243's that have 59cc chambers. Just wondering what issues I may run into if I pick these up. What compression ration would that put a stock ls1 at? Would it be OK on pump gas 92-93 octane. Any fly cutting needed? I do not have a cam yet, but would be buying and installing it with the heads. If so is it easily offset with using thicker head gaskets to get them back closer to the stock cc for these heads.
Old Nov 30, 2010 | 10:21 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Pump gas should be fine with those heads.
Talk to your tuner and/or whomever you're getting the cam from. They should be able to tell you if you need to fly cut.
For what it's worth, fly cutting is no big deal.
Old Nov 30, 2010 | 06:56 PM
JohnJ@Texas-Speed's Avatar
JohnJ@Texas-Speed
Premium Supporting Vendor
With 59cc chambers the compression will be at 11.1:1. Pump gas will work no problem on that kind of compression. Flycutting will depend on the size of your cam. Do you know the specs? Its always best to measure piston to valve before actually firing the motor once you get the cam in.
Old Nov 30, 2010 | 07:14 PM
BoostRetard
Currently running the stock ls1 cam, but if I get the heads I would most likely install something when I did the heads. Would thinkn I woiuld have something around 580/225 but not sure. I'm still used to ford 302 cams so small ls1 cams still seem fairly large to me when looking at the specs.
Old Nov 30, 2010 | 07:18 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I would say something around 228ish, or go big and get a MS3. I love the sound of mine!
Old Nov 30, 2010 | 07:19 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Texas Speed has a great selection of cams - from mild to wild...
As do other vendors on here. look around and ask on here... you'll get lots of different advice. there are a lot of videos on youtube of different cams as well.
Old Nov 30, 2010 | 09:41 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
LS6 243 castings come with 64cc chambers. I would ask how the seller how they achieved 59cc, weld build-up or shaving. If they were shaved I suggest you check for the desired push rod length with the push rod length checking tool, you may have to vary it to maintain optimum lifter pre-load.
Old Nov 30, 2010 | 10:48 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
ABSOLUTELY will need differnt pushrods
To 59cc heads...
