Caliper removal instructions
Old Apr 6, 2002 | 08:34 AM
ACCURATE's Avatar
ACCURATE
Default Caliper removal instructions
need info on removing the calipers and reinstalling and bleeding procedure , any links or threads would be appreciated .. :yesnod: Joe
Old Apr 6, 2002 | 10:26 AM
Elk's Avatar
Elk
Default Re: Caliper removal instructions (ACCURATE)
There isn't any real tricks to removing the calipers. The bolts you need to remove will be obvious once you get the wheels off. They will be on tight however, so make sure you have a nice long wrench handle. Be usre to have safety wire or something handy to tie the calipers to a suspension piece so they are not hanging by the brake lines as you are doing other work (like detaching them from the brake lines--also, if you are removing the lines, pump the brakes with the engine off until the pedal becomes hard. This removes the hydraulic pressure in the line).
I think there are bleeding instructions in tech tips. Nothing out of the ordinary.
Good luck!
Old Apr 6, 2002 | 11:00 AM
Jim 47's Avatar
Jim 47
Joe:
There are 2 bolts holding each calaper to its bracket. You will need a thin 5/8 open end wrench to hold the slide pin from rotating and a 15 mm box or open end rench to loosen the bolts. I suggest that you use a small amount of lock-tite on the bolts before replacing them.
Before you are able to remove the calapers, you should compress the outer pad toward the back side of the calaper. This can be done with a large "C" clamp. This action will compress the piston back into the calaper and provide the clearance to remove the calaper. If you have any problems give me a holler. I've done this so many times, I think I could do it blindfolded. :D
Old Apr 6, 2002 | 12:16 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Caliper removal instructions (Jim 47)
Slide pin is 16 mm push the rubber boot up you will see a flat spot on two sides
To Caliper removal instructions
