PS window & door locks not working
Old Dec 1, 2010 | 10:06 PM
bluemaggot's Avatar
bluemaggot
Default PS window & door locks not working
They've been intermittently not working for two years, but I could pull on the rubber accordian wire protector and they'd start working again. No more. I took the door panel off and expected to see something obvious like a cut wire or loose connection but I saw nothing wrong. The lights for the buttons don't come on either.
Old Dec 1, 2010 | 10:52 PM
Jnape's Avatar
Jnape
Pulling the door panel won't show you the harness connectors. They are stuffed into the door pilar. The connector pins or exposed wires will cause these issues.
Old Dec 1, 2010 | 11:23 PM
bluemaggot's Avatar
bluemaggot
Door pillar, like on the car side of the door hinge? I.e., sitting in the PS seat, looking at the rubber accordian, I should pull the left side off and dig in there for the connections?
Old Dec 1, 2010 | 11:30 PM
65GGvert's Avatar
65GGvert
Old Dec 1, 2010 | 11:31 PM
KCvetteowner's Avatar
KCvetteowner
http://forums.corvetteforum.com/c5-t...n-long-31.html
page 31 post #610....
Old Dec 2, 2010 | 06:33 PM
bluemaggot's Avatar
bluemaggot
Thanks.
Old Dec 2, 2010 | 08:25 PM
C5at57's Avatar
C5at57
If that doesn't fix your problem, swap the door control module to the other door and see if the problem travels or not. If it does, then you will need a new door control module. PM me, I have one.
Old May 26, 2011 | 12:57 AM
bluemaggot's Avatar
bluemaggot
I finally got back to this. I looked at the connectors, again and everything looks fine. I checked continuity across each connector also and they're all fine. I checked the four fuses having to do with the doors. I also switched the door control modules: the DS door works with the PS module, but the PS still doesn't work with the DS module. I checked the ground wire and it's good. The heavy gauge orange wire to the module has 12V. The fuse to the PS was blown out which made me happy because I thought I'd found the problem for cheap but that's not it.
I'm not sure what else to do.
To PS window & door locks not working
